I'm tired of crappy Sun Showers....any good ones out there?
I use to use the Zodi pump one you heated with its propane heater, but switched over to this nice one a few years ago.
It comes in a nice carry bag, and you can use the disposable 1 lb bottles, or use a bigger tank with the adapter hose.
Base Camp AquaCube Portable Water Heater/Shower
Had a few different designs over the years but in the end I carry a Nemo. The Nemo wins for me do to the smallest size, simplicity, efficiency, and ability to control temp by adding hot water.
I've been using the Ivation handheld on rafting trips, works pretty nice.
https://www.amazon.com/Ivation-Battery-Powered-Handheld-Portable-Shower/dp/B00IFHFJXI
If you want hot water you can just heat up some and plop the gizmo in the pot or a bucket. I usually just use it right out of a river but any water source will do, which is what I like about it, nothing to fill, hang or pump. Battery seems to last forever.
The stainless sprayers are nice though if you have the room, just put the whole thing up on the stove to heat.
The MSR Dromedary also has a shower attachment.
https://www.rei.com/search.html?q=msr+dromedary&ir=q:msr+dromedary&page=1
I've been using one of these for drinking water and contemplating getting another and the shower piece.
FYI- I have the domedary (red) and the shower piece is eh. The cut off is at the top. There's still a good cup of water in the tube. They should have made a cut off in the tube head.
On a side note, the katadyn shower head for their base camp also fits the dromedary. It has no hose. Its like the sun shower bags but much stronger.
The Kayadyn base camp also has a 10L capacity, but since it is a roll top, is easier to fill and clean. Always good to have options.
Yep.
Stainless 3-5 gallon chemical pump sprayer, with a counter-top sink spray nozzle.
Pretty much built to last a life-time.
Just have to boil a pot of water or use a solar water bag to fill it/heat it up.
Same here but I retained the brass nozzle but shortened the wand. Lengthened the hose with stout hose from O'Reilly. We leave it half full in the sun(painted black) and then boil water in the coffee pot. That goes into the sprayer. The adjustable nozzle atomizes the water and conserving it. Baja proven for 25 years. Down there we would fill the solar shower bag and take a pre shower with joy shampoo and salt water followed by a fresh water rinse.
I've painted ours black as well, but out sun isn't as good as your sun at warming it up :sombrero:
Instead, I leave a black water bag on the hood all day, then dump it in the tank.
Quite often, I dont even need to run a pot of water on the stove, as the bag does the trip.
Its a heavy duty canvas bag, found on a backpacking trip years ago.
Much heavier duty than the traditional walmart camp shower bag, complete with numerous eyelets for rope/carabiner attachment.
I'm not sure if the ZODI Outback Gear Extreme SC Hot Shower was mentioned or not. It holds 3 gals., will heat water to 100°, and the picture pretty well explains it's operation, It's rated 4.5 stars on Amazon, but at $161.90, it's a little pricey.
We used to build a form of this way back in 80's, using a 2.5 gal. Pressurized Water Can Fire Extinguisher. A lot of the newer ones have a plastic base to make it stand upright, but try to find one that has a metal base so it can be heated on a stove or fish cooker, etc. These have a pickup tube inside, so the can must be used up right for it to work. You can find these used on eBay, thrift shops, yard sales, surplus stores, etc.
These have a tire type valve stem mounted on the valve assembly, and can be pressurized to 100 psi. with a compressor or tire pump. Being a retired Firefighter, I know for a fact these things will shoot a 1/4" straight stream 25' for a good 1.5 to 2 minutes, so with the pressure reduced down by a diffused sprayer and intermittent use, it will last for a good bit.
amerex-stored-pressure-fire-extinguisher-empty-5.jpg amerex-stored-pressure-fire-extinguisher-empty-8.jpg
The hose will unscrew from the valve and you can replace it with a barbed fitting with 3/8" NP threads (IIRC). Then you can attach whatever hose and sprayer you want. Just remember, if you pressurize the system to 100 psi, and since water does not compress, it is coming out of the hose at 100 psi also. Pressurizing to 100 psi will allow you to use all of the water without having to re-pressurize, so what you may want to do is put a regulating valve inline where the hose connects to the valve assembly. This would allow you to adjust the system until you get it where you want it. Also, you need to make sure the hose and sprayer you use is capable of handling the pressure with the sprayer closed (static pressure), that you end up with.
The valve assembly is only screwed on hand tight, so it will come off fairly easy to fill it once the pressure is released. There is usually a fill line on there somewhere because you need a certain amount of space left for the air to compress in. You can heat water externally and then pour it into the can, or fill the can and heat it on a burner of some sort. Even though the can is very reflective, it will heat up some on a hot sunny day. You could paint it, but if you plan on still being able to heat it on a burner, be sure to use a heat resistant paint and don't paint the bottom.
I had thought about installing a thermometer similar to the ones used on BBQ grills, but there is no way to really get inside to secure the nut and washer, plus you risk creating a leak point. Generally, if you heat it to the point you just can lay your hand on the top part of the can without it burning you, it's about right.
View attachment 355137 View attachment 355138
Great idea....thanks.
No problem! I like a good strong shower and hate pumping, so that worked out pretty well for me.
Jlbeats
