Information on retrofitting H.I.D. headlamps
Are you sure about the 'whole housing' argument? HIDplanet forums had it going around that as long as you are taking the actual reflector/projector that met DOT specs and retrofitted into your housing, you were good to go.
Sorry, just saw this when looking for this thread to link to.
Am I sure? Well, the NHTSA writes the rules, the department I spoke with writes the interpretations and they say whole housing. And yes, I asked specifically if they meant complete assembly.
I'm sure people on forums say you can use reflectors that meat DOT and you're good to go. As I said before, people will hear what they want to hear.
From my buddy in the automotive lighting industry:
Scheinwerfermann said:
If you install complete compliant headlamp assemblies other than the original kind (modular self-contained compliant optics such as the Hella units, or headlamp assemblies from a different kind of vehicle, etc.), and the vehicle winds up with all required lighting and reflective functions, and they're installed such that they can be aimed correctly, you're legal. If you open up your headlamps and install optics and components (drill, cut, glue, screw, etc.) that weren't originally there, then (attempt to) reseal the headlamp, you're not. Even if the optics you install produce compliant beam patterns, by opening up your headlamp you've undone all the work to make the assembly vibrationproof, resistant to water and dirt entry, etc. And internal bezels and lenses often exert influence over the total light distribution via internal reflections, so if anything inside the headlamp changes, so does that, and you can easily get a noncompliance. Of course if you send your homemade headlamps for compliance testing and they pass, then you're legal.
Hey guys I'm new here and I think this maybe my first post!
Any way as for as lighting is concerned (from a law enforcement point of view) if the bulb doesn't match the what's stamped on the front of the housing it isn't going to fly.
For example my truck uses a H13 bulbs that means only H(alogen)13 bulbs can be used. Just because a HID fits in there, doesn't mean it should be there.
Also vehicle regs are pretty much standardized across Canada, US and Mexico due to the fact we have open borders between the three. The only time a state/province is different is when they have decided to get tougher than the standard.
Correct.
It is legal to swap complete units that would otherwise be legal to have been installed by an OE.
And by international agreement (UN 1956) ECE-compliant fixtures are also legal, again, ones meeting the same photometric requirements and already tested and independently assayed. Like Cibies, Hellas, but not IPF...
NMontanari
