Inner tube for trail/BFE repair?
On the farm we got a lot of 'miles' out of a tractor tire by sewing across the hole in the sidewall with tie wire and putting a flattened coffee can inside the tire to keep the tube from extruding out the holes. Tractor tires are expensive on a small farm budget. :)
We use the same basic repair on ripped sidewalls all the time. Except instead of a coffee can we just apply a large patch over the area and run a tube. (then we quit running cheap chinese tires and haven't needed to in years)
Tubes can be a little trickier to find at places that service car/ truck tires. Find a place that sells ag or construction equipment tires, they use tubes on a regular basis.
So in an effort to save some space in my Tacoma, I'd like to carry just one full size spare, not two. In place of that, I figure I can carry a couple of inner tubes and tire spoons to break and reseat the bead.
Anyone have experience using tubes as a temporary repair method? Everything Google finds is related to bicycles and dirt bikes.
I think that carrying a spare and a tube is a great alternative to carrying two spares. I think its a really rare situation when you have two flats, let alone two flats that cant be repaired well enough in the field to get you to a tire store. As long as you know how to break down a tire manually your good to go. A high-lift jack is usually all you need to break the bead and a cheap set set of tire spoons will get the job done.
Be sure to get radial tubes (assuming your tires are radials) and some tire talc to dust between the tube and tire.
Yep, tire talc or even talcum powder works. (just make sure everything is dry inside)
If you have the air source, it's a good idea to inflate the tube some (after it's installed), then pull the valve stem and deflate it.
This eliminates any folds and twists in the tube before full inflation.
Bobbyjr
