rossvtaylor
Hi gang,
Sorry to muddy the recovery section with this mundane issue... but, I looked online and no joy...
I've got a used Warn M12000 we're installing on the front of our rig. It came pre-mounted to a bracket which will fit nicely on our frame rail extensions - so, we lucked out there. To make this all easier, I'm trying to remove the winch from the mounting bracket. But, I can't remove two socket (Allen®) head screws on the front, behind the fairlead. They take a 1/4-inch hex wrench and I've already bent a good one. I don't want to bust off a screw. I tried a sharp rap with a hammer, to try busting loose any binding corrosion. Didn't work. I sprayed, where I can, with penetrating lube... but, that didn't work either because (with the sleeves/spacers) I can't get lube into the threads... only the head. Heat might work, but I'm reluctant to torch the winch body.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Screen Shot 2016-08-27 at 11.14.35 AM.jpg Screen Shot 2016-08-27 at 11.14.35 AM.jpg](https://expeditionportal.com/forum/data/attachments/281/281163-27879fcbf278a309808d7fb5bcf23e78.jpg)
![Screen Shot 2016-08-27 at 11.15.06 AM.jpg Screen Shot 2016-08-27 at 11.15.06 AM.jpg](https://expeditionportal.com/forum/data/attachments/281/281164-9fdb3178459f399be69b7554d716f7f4.jpg)
Am I missing a lock nut or something, hidden, that I'm not seeing? Anyone, who has taken these out, know if there's anything I'm doing wrong or missing?
Although I can leave it all assembled (and will, if I can't remove these two screws), it would sure be easier to handle the bracket alone during the fitting process. It's a bit of a pig...
Thanks much!
Thanks much!
