nickw
So I have been kicking around the idea to throw in some lower gears. I have been debating 5.29's if/when I went with the 255/85's but had no idea how it may impact my mileage so I thought I would do a quick comparison.
I had to make the trip up to Olympia from Portland a couple time this last week and decided to take advantage of the flat I5 route. Mostly flat with only a few slight inclines, no hills to speak of.
I have done the calcs and running the 5.29's with the 33.2" 255/85's is 'roughly' similiar to my current 4.10, 31.8" 265/75's in 4th gear. I set the cruise to 100kph which netted an overal RPM of 2700 and kept it pretty steady for the 112 or so miles.
I drove back to Portland then headed back up to Olympia just to make sure I was driving the exact same route with the same hills. This time I dropped it down into OD which put the RPMs in the 2250 range. I even filled up at the exact same station both times.
Results as follows:
Trip up @ 2700 rpm - 17.75 mpg
Trip up @ 2250 rpm - 20.75 mpg
This may not surprise some, but I was quite shocked at the results. I was always under the assumption that the 3.4 would be more effecient higher in the RPM range since it makes max torque above 3K.
Results as follows:
