Is a CDL a must?
Akrange said:
but the minute my truck can't do something that a lot of the others can, I seem to get lumped back in with all the other 'girls'. I hate that!
Yes, but in men's defense, we'd say the same thing to Dave if he can't do it, so....
Ok, practice with me: "Hon, I need to buy a couple things, The LT230 lockers, axles and have you put them in and some seals....do you want anything too?"
Works like a charm.
Works like a charm.
:xxrotflma :xxrotflma :xxrotflma Oh, I bet that would work! You guys can be so easy sometimes :elkgrin:
Just to put my .02 in... I've always been one for relaibility over fun. As some of the guys have said, the CDL is going to get you a lot of control over your vehicle with a lesser chance of trail carnage than going straight for the big boys... (The Slip/Catch factor)
But I'm also going to add the Ease factor into the equation as well. You can run a trail with the CDL locked. I really try to use lockers only when I really need them and I could almost seeing full lockers as being a bit of "overkill" (like using a baseball bat to squish an ant).
But in the end it comes down to $, opportunity, and your abilities on and off the trail... If you do got the LT230 route PULL THAT SHIFT LOCK!!!!! It is such a PITA!
Happy trails!
Ran Slickrock and Deer Valley with NCLR over the weekend http://spaces.msn.com/conalmack
The CDL enabled one LR to drive 200 miles home after breaking an axle climbing the gate keeper on the Slickrock in Northern CA (the GBR heavy duty axles were already transferred to the "other" Disco). I have a P38 with the viscous CD and TruTracs, (carry spare axle assemblies), i replaced the diffs with the stronger carrier and TT after destroying the spider gear on Metal Masher in Moab (and still drove back) but that was less than ideal with the viscous CD.
If it were my Classic RR i would definitely do the CDL, it does improve trail performance but the advantage IMO would be in the ability to drive off the trail in 2wd should you encounter mechanical drivetrain issues.
A basically stock (mild lift, and BFG's) RR Classic is a very capable trail vehicle for the terrain here in CA.
Pictures at http://spaces.msn.com/conalmack
I haven't wheeled with Shawna a lot, but she went on a night run with the club a few weeks ago, she definitely can drive. If she's uncertain she asks for advice but then goes for it. I saw patience and both smooth acceleration and slowing down. It wasn't a jerky driving style. Actually, I think on this last run she out drove her truck. What I mean by this was that it wasn't her skill that was lacking it was the build of the rig.
Not being a Land Rover guy or really having any experience with them at all other than a few D90s which are a completely different beast. It seems she could have used a little more flex. The front of her rig and more particularly Dave's Disco 2 don't seem to flex as much as I was anticipating. I was expecting them to react similarly to an 80 series Land Cruiser. In chatting with them it seemed to make sense that adding a rear locker would make the most sense. They can't go with larger tires without doing serious axle modifications so adding a taller spring doesn't make sense. And really in this day and age who wants to daily drive with big tires when gas is over $4 a gallon and surely it will rise more in the next year.
They face the same problem I do. Our local trails have a lot of washes, a lot of dirt roads, but eventually they will have some rocks. It isn't continuous rock, but they are enough of an obstacle that some consideration to these formations should be given when building a rig for this area. So we aren't really rock crawlers, but we are to some extent for short intervals on a trip. It makes building a rig a challenge as building a rig for highway, gravel, two tracks and building a rig for the rocks are two different types of builds.
At this point I think adding a rear locker makes sense, because I don't think a flexy suspension with big tires is really an option.
ginericLC said:
Actually, The guys would rather have Shawna up with us and we'd like to see Dave hang out with the other women wheelers. That way we have everyone grouped by ability ;)
Baaah!
You're probably right though ... why do you think I put a lift and tires on my truck before Shawna's! I need all the help I can get!
M meadow build
