Is anyone running 16" or 17" Alloy wheels and skinny 33's?
Im running a 285/75R16 Firestone Destination M/T on 16" Moabs. There a little louder than I like and, wider. How is the noise with the KM2's in the 255/85 size?
I'm running these 34/10.5/r16 bias-ply LTBs on 16x8 Moab wheels
Despite being a '34', actual measurement mounted new was 33.5. They do awesome off-road, and clean out very well. The narrowness gives a little more bite than the 12.50 tires. Never aired them down on the trail though(no OBA). They run well at highway speeds (70+ mph), and are actually quieter than the Nokian M/Ts they replaced. Out of my set of 5, 4 took minimal weights for proper balance, and the spare took quite a bit, but did balance out. Only downside is the soft compound makes them wear pretty quickly on the pavement. Two summers of DD use and mine will be pretty bald.
Goul6891,
I like to see more pics of you running those tires if you have them.
Bill, did you consider getting them siped? We'll be using a set of 255/80-17's on the new JKUR, and they will have the center lugs siped by Discount tire just to avoid the traction problems you describe.
I thought about it --- after I got rid of them.
For the money, I'd just rather buy tires that work right and don't need tinkering though. Coopers all the way.
16" stock MOAB rims and 255/85 km2's, really works well and very happy with the setup. Had 35's before and like this much better for a mix of highway and offroad!
Nice. Looks great.
Do you have a lift to accommodate those 255/85's ?
Thanks,
-Dan
HButton
