Isuzu NPS 300 Winch
SkiFreak
Crazy Person
If you are planning on using the ATW winch bar with a winch that has synthetic rope, opposed to steel cable, you will need to add some bits to hold the fairlead.
Should you be interested, you can see how I did my install here.
whatcharterboat
Thanks Guys I thought that may be the case John as mines a 2009 and yes I'm thinking of a Runva 17500 . It's good to know that fits the ATW Bar for the 15000 winch.
Isn't the 17500 Runva the same format , mounting, etc as the 15000 but with the slower gearing?
SkiFreak
Crazy Person
My Runva 17.500 lbs winch has an 8 bolt mount, opposed to the 4 bolt mount of the 15,000 lbs model.
You could probably get away with just using 4 bolts on the 17,500, but I chose not to.
DanoWall
