Its a dream but a good dream !
Stair well done and the floor in the bedroom.
For people that are going to the Overland expo. The truck will be their so stop buy and take a look. At this time, I don't know if it will be at the training area yet ? I have a spot in the RV park. But I will be with the "Re-purposing vehicles for Overland travel " Will be helping "Bevan Walsh" if he still wants me. LOL. That's Fri 2 to 2:50 and Sat. 10 to 10:50. Its not my next project "the M1078" but it has lots of the building that will go into the M1078.
Will be staying in it for the weekend. Don't be a stranger and stop buy. B.Y.O.
Randy
O the way to Expo 2017 I had a little " Problem " ! Lost a driver side front tire. Don't be a dumb *** like me . Get new tires every 5 to 7 years unless you where them out before.
But worked it out and got their late and missed the truck building class with Bevan,sorry !
Glad you made it there safely! Tires are one of those things that can look fine until they're not. My LMTV tires are out of date but they were out of date before they were ever on a vehicle so I THINK I'm good for a couple of years. If not I have 3 spares that are equally new and equally out of date. Oh, and I have EXCELLENT tow coverage on my insurance in case they aren't any good.
Good day . Water tested and LP.
attachment.php
Just a quick note about your plumbing.
Unless I cannot see it in the photos, you REALLY need to use some dielectric unions whenever you go from copper to galvanized pipe/fittings.
Galvanic corrosion will quickly set in if you do not.
Beyond that, all looks great :victory:
Thanks . I will look into that.
Are we talking about a "LP" line or a water line ?
I was told ,that with out a electrolyte (water), I was ok ?
Galvanic corrosion is often a misunderstood topic. I am very familiar with it when it comes to salt water. Less in atmosphere.
If you have two dissimilar metals that are electrically connected in an electrolyte, you create a battery. This battery drives electrons to one pole of the battery which causes oxidation at the anode. The anode starts to corrode faster. Incidentally, the other pole is protected.
The further apart two metals are on the galvanic series (google it for reference), the higher the voltage potential. Also, the stronger the electrolyte the greater the corrosion. If you are running a water through your pipes, you may have galvanic corrosion.
Also, the proximity of the materials to each other affect the corrosion rate. Think of it like you have a resistor between your poles in your battery. The further apart the dissimilar metals are the higher the resistor you have. If you put insulators between your materials, it is even better. If you reduce the exposed area of your materials it is also better.
Materials that passivate, like stainless, aluminum, titanium, etc..... have two values depending on if they are passive or active.
In the atmosphere, galvanic potential can increase the corrosion rate, but it is less of a problem.
I generally look at where the material is going to be and then decide if I really care. If your pipes are inside your camper, and used for gas, you may not have any issues for years. You could also paint the pipes. Inside the pipes you may condense water possibly, but how many years would it take to be a problem? Also, corrosion is a naturally occurring event. You may get corrosion regardless of galvanic potential.
I always find it odd that camper builders are always harping on isolating aluminum skins from steel frames. They will paint the aluminum and steel, then use sikaflex between them. Then take additional effort to isolate the materials with spacers and tapes. The aluminum is the anode in this case, the galvanic potential is relatively low, and all surfaces are painted and separated by glue. That should be enough. Adding tapes and setting spacers to me is just more work. If you see corrosion, it is probably due to a gap in the paint, and probably only matters if the steel is rusting. Or, where a rivet is, there is exposed metal due to drilling a hole. I would wager that most times the problem is caused by excessive numbers of rivets that are poorly sealed. A decent quality aluminum skin should passivate itself unless you are simply in a very corrosive environment. Then the environment is the problem more than the materials. Just my two cents.
Corrosion is often hated because it looks bad. Functionally it may or may not be a problem depending on the rate of corrosion, the amount of damage, the type of corrosion, and where it is.
By the way..... love the build. I look forward to the next one!
I have not stopped. I just needed my table saw setup for making the doors. I got a fence system but needed to make a new stand. All most done. then back to the truck's.
When this is done I will have square doors, with luck ? LOL
You got that right.
But the cabinets are, so the doors need to be also ! LOL
Sorry, I for got to tell you that the sink faucet was a pain to seal up. All 3 of my fittings leaked. First the cold, then the hot then I put the city water to it and the feed to the sprayer. Was a pain. But works great.
You got that right.
Ha no worries, that's exactly where 2 of my leaks were too! You really have to crank those fittings down (I used the 3/8 to 1/2 mip adapter) but man washing your hands is nice camping!
Sent from my SM-G900T using Tapatalk
Wolfbox
