Its a dream but a good dream !
I have not posted the "DIY" part of this build because I'm a hack. So here is what happens to a 4x8 pic of plywood.
Then.
And now upper bath storage.
And finished the front upper storage.
Wired up the LP heater. Thanks Allan ! Did this waiting for stain to dry. Now on to clear.
Will do the install in the bedroom tomorrow but have not worked out the front room ?
Also still need to run the LP to the heater and the cook top but that is next week.
Finishing up the bed room heat outlet.
Also mounted the water outlet's under the sink. Test fit the faucet lines also.
No photos today,to tired.
Rigged the LP for the cook top, heater water heater and the out side grill.
Installed the sink, sink top, cook top insert and plumbed the kitchen sink.
Why does it it leak ? The fittings are only 15 years + old and have never been under pressure before ? Plastic ? Junk ?
So off to HD for some "Shark Bite " fittings. $$$ Wife is not going to like the bill.
How about this ?
Also got the water system tested along with the LP !
Some things have been moved around but it is close.
Another long day.
Got the new Grill gas line made and installed and leak tested. We have Grill !
Finished the wiring for the Invert-er/charger and tested. Now that is a big fuse ! 250 amp's.
And full LP tanks.
Almost for got. The USB charge station and the rear light switch are in the driver's dash. The switch turns they's lights on.
Now I can turn them on from the cab or the back. Cool. Now I just need to build the lift for the Rhino. ! Maybe next week ? No ,going to Overland.:oops:
Wolfbox
