Jack points for a 2003 Montero
ChrisCosta416
What is the proper way to jack and layout jack stands on the Monteros?
I have been doing the following
Jacking points
- Front Crossmember
- Rear Diff
Jack stand points
- Rocker panels for front and back
Is this the correct way?!
nckwltn
Jacking points
- Front Crossmember
- Rear Diff
Jack stand points
Does the FSM show any jack points? I forget exactly where I put the jack when I had a gen 3, but I always had a block of wood between the jack dn where ever I was lifting at.
Sent from my LG-H932 using Tapatalk
ChrisCosta416
Thank you! I searched "jack" in the index but came up with nothing. This works!
I jacked the Monty up from the rear diff last week, do you think I messed up anything?
Monty85
Welcome!
I think you are fine about Diff unless you cracked or dented it. I would use cross member.
For me, I cannot lift high enough with my jack so I put piece of wood under crossmember.
For stand, FSM shows to put it on pinch weld but I put it on body frame. Works ok for me.
bdpkauai
