JK 4-door to 2-door long wheelbase conversion.....
I didn't see anyone post "Sarge" up here. I always liked this:
A carbon hard top would be awesome, But prob around $10K or more.
River Raider has just come out with a carbon fiber/fiberglass hood.
Road Race Motorsports is working on one. They also just came out with a carbon grille, Won't save much weight there.
You could save a ton of weight if you did carbon fiber doors/door panels, rear door, upper windshield frame.
Then you've also got super light weight Braille batteries.
All that I mentioned would probably cost $20K or more lol.
How about asking A/T to make a habitat without the provision for the rear doors?
If you ask A/T, then A/T would ask me. (I designed and my company builds the Habitat that AT distributes – so maybe I’ll save you a call.) The hard tooling we use for the Habitat is pretty set, so it’s not something we could do as a production part – it would be all custom work.
I was looking at the JK top a little more in depth. To me it looks like the top is made in multiple parts and then basically glued together? It looks like the panel where the side window is could perhaps be removed and a new longer windowless panel fitted.
The JK top is made out of formed sheet molded composite parts, once those are bonded together it’s not coming apart without some damage to the flanges, you could try really getting it hot to see if it breaks the chemical bonds, but a lot of times the stuff will fracture before the adhesive will. You could probably cut out a section with a wheel.
Why not just remake the entire top in carbon fiber while you’re at it. I wonder how light that would end up being?
It would probably not be that much lighter than the original top. Replace structural steel with carbon fiber, there can be a serious weight savings. The JK top mostly keeps the rain off the interior, it’s not adding any rigidity to the vehicle chassis. Replacing something non-structural that’s already fiberglass, you’re starting with a fairly light part – JK Top is maybe 140 lbs. So something similar out of carbon even on a thin core might be 10 – 20% lighter, but to go really light, say 50%, would be rather expensive for both the materials – and the tooling/processing needed to deliver a decent part. So you’d be paying $$$$$ to save 70#. Maybe the military has that kind of budget.
Probably be better to make the bumpers out of carbon…hmmmmmmm
I am sure if they make it, they could sell enough to warrant the cost.
So, to all those here – a OEM or aftermarket JK hard top runs something like $2000- $3000 depending on what’s included (rear window and such) Probably buy a used one for $1000 if you want to modify it. What do you figure you’d be ready to pay for a new utility JK Unlimited shell like the photoshop photos (or close anyway)? That's what Snugtop or anyone else might want to know!
I'm trying to get away from full frame up rebuilds :) Its not that I don't enjoy it, but I am looking for something NOT a full frame up rebuild next time.
Is anyone a member of SEMA that uses the tech transfer program? I am interested to see if the CAD data for the top is available...
This is kinda an offshoot of another thread, but this idea has been going around in my head all day......
Basically a kit that would convert a 4-door JK into a long wheelbase 2-door version. Replace the rear doors with inserts that would bolt in and a new one piece top to replace the factory version.....
Personally I don't need or want the 4-door JK rear doors, seats, etc. I just want more room in the rear cargo area for storage, sleeping, etc. I have to think that eliminating the rear doors with inserts could make it a bit lighter, cleaner, and more simple overall. I'm thinking the top could be a simple one piece unit manufactured out of strong composite material with an insulated honeycomb top to help with noise, sun, and cold temps.
What I am thinking is a USA available version of something like this.....
Anyone else ever thought about something along these lines?
IF only we could get our hands on some bolt on side pannels from the jk8 bolt on kit...............
The JK8 kit is available, so im sure that a body shop could order just the side panels from that kit. There is a thread covering the conversion of a JKU to a JK8 on here right now. It looks pretty involved but doable to someone with time and some skills.
I posted the part numbers for all the single parts a little bit back. The bolt-on version of the body panels where just cut up J8 body panels. If I was going to go with a bolt in version of the kit I would probably just do a door insert. The B-pillar on the 4-door makes a top a little harder.
I will look into it,,,, the only reason i have not gone topless and door less with my jku is because i hate the looks without the doors,
but i will be happy either with those side panels or even half doors in the back , topless and door less in the front.
5mouse
