psykokid
I mainly got my HAM ticket to have better comms than FRS could provide when offroading. Now that I have my ticket and stumbled upon APRS I've seemed to find a new rabbit hole to fall down into.
For right now I just have a UV-5R along with a nice Diamond NR770HBNMO on an NMO mag mount. Decent send and receive for a small radio with only 4W. Eventually I'll get a mobile rig, something like the Yaesu FTM-350AR with the GPS module. Although it's been discontinued used units pop up from time to time. Spending that on a mobile rig isnt in the cards at the moment
For the time being I want to get an APRS setup up and running. It will help me keep my wife in the loop when we're out in the middle of no where (she's a worrier) without the expense and fees of a SPOT or similar. I was thinking about either getting an all in one transmit only solution like Byonics Micro-Trak RTG FA. All said and done it's $220 plus shipping with an antenna and gps puck. Not too bad but it kind of side steps one of the great features of APRS which is the ability to communicate both ways. I've seen APRSdroid which is a nice implementation of APRS over cellular data using APRS-IS. Thats all fine and dandy but when you're out in the middle of no where there's usually no cell signal. Turns out there are a few other features in APRSdroid which includes AFSK which allows you to connect an audio cable to your android device and then connect the other end to your radio to send out over your radio. I found an implementation of it HERE using just a Baofeng UV-3R and an android phone. Not too shabby..
This got the wheels a turning. How about using a bluetooth adapter like a Pryme BT-501 with a UV-5R? I already have a Samsung Galaxy Tab2 7" that I use when offroading for mapping. The Pryme BT-501 adapter is setup for Kenwood radios which the Baofeng UV-5R seems to use the same type of connector so that should work there. Find a cheap mag mount antenna for the roof, pick up the BT-501 adapter which i've found for around $90 shipped and another UV-5R for $30 from amazon along with the APRSdroid app and i should be good to go. I figure I could have a solution for around $150 all in.. I could go with just a cable solution and keep it even cheaper but I don't need more wires and crap inside the cab of the truck. Using bluetooth and keeping it wireless will help me from keeping the inside of my truck looking like this:
Any comments or suggestions?
