Superu
Just completed a simple winter lighting mod that has proven very effective on the Suburban.
I run a pair of Hella 500s with clear covers on the push bar as auxiliary high beams most of the year. What I find challenging is getting proper light for the snowy conditions we get up here in VT.
Solution step 1: applied Lamin-x yellow films to the clear covers on the Hellas and adjusted the aim to move down and out a bit. I may flip the mount to hang them below the center of the push bar to get them a bit lower.
Solution step 2: replaced high beam bulbs with 65w yellows.
As luck would have it, I had a chance to drive through a snow squall the day after the mod and was very pleased with the results. Light reflection off the snow was dramatically reduced, long range visibility was still very good and overall this works much better than I expected!
Essentially, this is a relatively low cost, reversible mod that addresses the specific lighting needs of this driver. It may not be the best for everyone, but it works for me so I thought I'd share it.
Will get some pics up soon.
