theksmith
i just finished my on-board-hot-shower system this evening and i've done a very complete writeup over the past couple days that i thought i'd share: http://www.offroadpassport.com/forum/showthread.php?t=754
it's yet to be field tested, so there will be tweaks i'm sure. here's the the short version:
10 plate heat exchanger: $45
Shurflo Classic RV pump: $65
Shurflo filter: $10
Watts variable thermostatic mixing valve: $25
Initial handheld shower head and hoses: $30
Waterproof switch, wire, protective loom, inline fuse holder, fuse, connectors: $20
Brass fittings, PVC flex hose, heater hose, steel, aluminum, paint, bolts, nuts, washers: ~$125
Scepter plastic water Jerry cans: $65
Shurflo filter: $10
