Thanks for all the replies and input, I am going to go with the XR 400 as it seems the most reasonable choice across all the categories. I figure its better to buy a little cheaper bike and spend some money on good riding gear that I can take from bike to bike. If the XR proves itself, awesome, if not no harm no foul. As for hitch mounting it, I am not worried with either choice as my buddy hauls both (not at the same time) on a hitch mount on the back of his 2001 F150 Super-Crew. When I get out to Cali to have the suspension upgraded at Agile I will have him add the appropriate helper spring and valve the shocks accordingly. As for my intended use, mostly service/fire roads, CBCDR, and a bit of double track,no more than 125-50 miles in a day, 99% single rider, maybe an occasional double up for a short distance to get out of a campsite without having to dismantle the whole thing! And a side note to the starting issue with the XR, the PO has already installed the pumper carb kit for it, fires up 1-2 kick.
the XR400 is the way to go between those two bikes. The KTM is a hotrod but brings with it exponentially more maintenance. The DRZ400 mentioned is less reliable than the XR in stock form and is water-cooled, which means more maintenance. That XR sounds well setup and time-tested. They are stone reliable and very simple machines with long service lives and broad aftermarket parts availability. My .02.
Can you use this with an extension? My spare tire is door mounted now and will be Bumper mounted this summer when I get my upgrade.
