Mitsubishi Parts Availability
parts for Canter 94
Hi,
Thanks for your input guys. Re finding parts, we are currently facing a similar issue here visiting California with our 94 Canter FG 538 imported from Japan.
Some parts are alike the Fuso, others not. We are currently exploring some options and will let you know when we have some reliable data.
Best
Robert
Hi Robert & Martine,how are you guys? if you have any probs with spares let me know and I will try to source them locally I think the Jap & Aust specs are very similar,if you send me the vehicle details to keep on file will make things easier to order.
We will be in Argentina around September,will be good to catch up again if you're around.
all the best
Joe Baz
CANTER - References for FILTERS, oil, air, diesel
I am a bit lost with all the threads, however, if you have not already found this on ExpeditionPortal:
Canter FG june 1994 - model FG 538B - engine 4D35 OAZF
Note: RHD - 24 Volts
Oil Filter
FRAM = PH8936 WIX= 516 75
NAPA= 1675 BALDWIN= B7121
DONALDSON= P 502 008 LUBER-FINER= LFP 8752
Diesel Fuel Filter
NAPA GOLD= 3397 BALDWIN= BF720
DONALDSON= P 55 02 45 FRAM= P7075
LUBER-FINER= LFF 3886 WIX= 333 97
Air Filter
FLEETGUARD AF25438 FLEETGRD
I don't know if it applies to Fuso, but it would be useful to either Canter or Fuso owners...
This is not Fuso specific, but it may be of help to someone traveling to South America, and especially Peru. I had to get some work done on my Mitsubishi Delica van today, and it is always a challenge due to lack of parts. It is a Japanese model that has been converted from right to left hand drive here in Peru. The main reason I was taking it to the shop was because the sliding side door wasn't closing completely on the top, and lots of dust was getting inside. I took it to a large Bosch diesel service center here in Arequipa, where I have always gotten it worked on. They work on everything from Japanese cars with diesels to heavy Caterpillar equipment, and everything else in between, including lots of Toyota pickups, MB Sprinter vans, buses, heavy duty trucks. Today I saw a old Mercedes military truck there, but couldn't tell what model is was, a Mahindra pickup and some cute little Chinese flatbed trucks (new). I was also reminded to try again to get the cold stalling problem checked, as it kept dying on me when I was trying to get the van going this morning.
The door problem was caused by a worn slider (hard plastic roller) on the top of the door, that is supposed to pull the door in tight when it is closed. Here you usually can go buy your own parts and the mechanic will install them for you, which is cheaper than having them get the parts. The place for parts in Arequipa is on calle Puno, which is near the repair shop. After checking many stores with no success, we finally got a bearing about the same size, and were told to take it to a Torneria (machine shop) to put it on the arm. The machinist said he could do that for 10 soles or make and put on a new plastic roller for 20 soles, which I decided to have him do. He said it would be ready in just over an hour. We went back to check on the van and were told the stalling problem was caused by the hand pump unit on top of the fuel filter, I don't know what it is called.
Back to calle Puno to get one of them. We were sold a "generic" one for some Mitsubishi. I expected it to be expensive, but it was only 35 soles, my friend got it for 32 soles (he almost never pays the asking price). We also needed a short hose for the turbo intercooler, so had to go to the "hose" store. He found a long one the right size, and cut of a piece to match what we needed - 5 soles. Back to the Torneria at the set time, he hadn't started on it yet. My friend waited there for that and I took the other parts back to the mechanic.
About an hour later he had the intercooler and fuel system back together but my friend wasn't back with the door part yet. He showed up about 30 minutes later, the mechanic had just left for lunch. We went home for lunch and returned a couple of hours later. The door worked but was hard to open and close. After cleaning and lubing the channel, it worked OK. I had asked the service manager there to have a few missing bolts replaced that hold on part of the grill and trim pieces. That hadn't been done yet so found the mechanic and got that done. The plastic headlamp bezel also had some broken tabs so that wasn't secure. They had tried to epoxy them before but it didn't hold, so it was just taped in place with wide clear tape. I suggested making a small "L" shaped clamp out of metal that would hold it together, he also did that. These extras took at least 30 minutes. The bill for 3+ hours of work came to 50 soles (including bolts and making the clamp), total including parts was 107 soles, or US$37.40
As hard as it is for me to communicate with the mechanics here, I sure am going to miss the cheap prices when I get back to the U.S.!
To wrap this up, and hopefully be of some help to others, here is what you need to know, at least in Peru.
Taller - garage or repair shop (in general a workshop or studio)
Mechanico - mechanic
Torneria - machine shop (metal lathe and more)
Soldador - a welder
Respuestos - repair parts
The parts stores tend to all be in one area, in Arequipa the best place is calle Puno - about 3 blocks of small parts stores, also a couple of machine shops. The mechanics are usually nearby. There are a couple of other places as well, including some that specialize in big trucks. Many parts stores don't use parts books - you need to take in the old part and ask for one like it. They may get out the calipers and measure the diameter, threads, etc. The bigger and better stores may have a parts book, and even use it sometimes! The part probably will be a little different than the original, you may need to take it to the Torneria or the Soldador to modify it, or the mechanic will make it work somehow. It is very hard to return items, exchanges are a little easier. There are also used parts stores, some in the same area and others in their own special areas. As Doug said, there are no junk yards, everything is stripped down and reused.
Have fun! :sombrero:
Vic
PS They will get grease all over your vehicle and on the floor mats/carpet. Plastic wire ties are acceptable replacements for screws and bolts, if they even bother with them. Nothing is ready when promised - take something to read. Good enough is good enough - as long as it works - after replacing the broken passenger window in my van, up is down and down is up, (it's electric).
Hello to all future Fuso owners and lovers,
It seems that there is a big misconception regarding Fuso parts. We keep hearing that Fuso parts are available anywhere in the world. We hate to burst your bubble, but based on travelling in over 40 countries with our trusty 2004 FG 639, the only countries that stock parts for our vehicle are those countries that sell 4x4 Fusos ie: Australia, New Zealand and the US. Other countries that sell Mitsubishi trucks do not have parts for the 4x4 Fusos. They can all work on the vehicle (except in Scandinavia, and one dealer in Germany), but we have always had to supply the parts ourselves. Everything, from filters to brakes to bushings etc., we have had to provide them. Not to mention the fact that our local dealer in Mesa/Phoenix refuses to ship internationally.
If someone has had a different experience we would love to know about it. We would love to be able to buy our parts from dealers outside of the US.
Don't get us wrong, we love our Fuso dearly and wouldn't change a thing about it, but this parts thing has been an issue and is very frustrating. :(
Kim & Don Greene
Adventure Learning Foundation
www.questconnect.org
Americas Overland
www.americasoverland.net
Harvest Hosts
www.harvesthosts.com
Parts available worldwide... Check http://www.expeditionportal.com/for...uso-Canter-spare-parts-Worldwide-useful-data-!
and also a post specific to oil and air filters (search for kookynet in the forum)
Shocks for FG538B
The stock shocks have Mitsubishi part numbers:
- MC110328 FRont
- MC114 594 ReaR
I changed them 15000 km ago (been driving on Baja California dirt roads)
------- I checked Geometry of truck FG538B. It could accept without risk
Front compressed 13" or less - extended 18" or more (< 330 and > 455 mm)
Rear compressed 13.4" or less - extended 18.4" or more (< 340 and > 469 mm)
------ ONE Replacement I found so far is
Front Monroe Gas-magnum 34928 compressed 13.25" extended 21" ( 336 - 533 mm)
Rear Monroe Gas-magnum 34803 compressed 11.62" extended 18.5" ( 295 - 470 mm)
Safe drive. Best
Robert
5mouse
