Recon, do you still have the H3? Nice looking Jeep.
www.getlostoverlanding.com
Yes sir! No plans to get rid of it. It's been delegated exclusively to emergency work, so the rear seats are gone and it's full of recovery and emergency gear. That's why I got the JK. It's for daily use and for family outings. The JK will still be geared up for emergency work too. Just not as extreme. Simply because you never know when I may be needed that I don't have time to go get to the Hummer first. It's already happened a few times. During hurricane Matthew, the Hummer came out due to the severity of the emergency.
Oh wow I like that there. I am going to have to look into that. Looks great!![]()
Installed the front molle panel. It's Spod compatible and also great for stuff like a CB or OBD Scanner/Gauges.
All the newer tac vehicles have switched to green interior lights...red makes sweat look like blood.
Nice updates. :beer:
On the exhaust, it is really well tuned for best performance, so be careful with mods on that.
I've not had any damage to the "trumpet", and the cross over pipe is protected by an M.O.R.E. trans/engine skid plate, which also protects the transmission cross member.
The transmission cross member, and the front of the fuel tank skid plate is really vulnerable to damage, as that is the break over point.
Since you already have the cool ORE skids, it might be worthwhile to have a piece of 3/16" plate bent that could mount to the cross member and go slightly in front of the cross over pipe.
Something like a much shallower version of this: \__/
If you can protect your fuel tank skid plate before you go off road the first time, you'll be happy. I dented in and banged out the stock skid a few times before installing an aluminum skid over top. Installing the skid plate over top was kind of a PITA, because each time the stock skid plate was hammered out, the metal stretched a bit. So fitment took a bit of time.
Hth,
