Next, I wanted a dimmable light on the side of the tent where I rest my head. This would have a switch on the inside, and I would be able to dim the light for reading or hangout out before bed.
The main reason I took on this project was that I needed a 12volt power source in the tent for my 12 volt heated blanket that I use to warm up the bed on really cold nights. Since the mattress takes up the entire floor space, there was no place to install a dedicated panel. I decided the best way to handle this was to have something like a remote, but on a cord.
I went to Autozone and found a three port 12 volt power block with an extension cord, that also had a USB port. Three ports is overkill for me, so I used one of the ports to install the switch for the main tent light. I had to gut the unit to make it work, but so far it seems to work fine. The other nice thing is that it has a master on/off switch. The USB port will be great for my phone, tablet, etc.
Here it is on the workbench after reassembly
I have a plug between the tent and trailer so I can remove, or install the tent on the 4Runner if I ever decide to.
An octopus of wiring, I had to give the wiring enough room to fold back up into the tent without getting pulled apart.
