My new popup, what is it?
coulter6
My vote is for Northstar. The corners sure look like what Northstar uses, here's a pic from the Northstar webpage:
I used 2" pink high density foam to raise my camper to clear the cab. It's lightweight and easy to use.
jkce72
It looks like a few of the camper companies use that same roof and corners. I'm leaning towards it being a Northstar though. Pink foam, what a great idea. Light weight and rigid. Hows it holding up?
coulter6
You can see slight indentations of the camper frame in the foam, other that that, it works great. Ther camper is on the truck most of the time, so the indentations are from it being on for over a year. It also helps stop the movement of the camper in the bed.
You should a pic to Northstar and see is the claim it as one of theirs.
Ancientsojourners
