The previous owner had a new set of tires put on roadside and I'm pretty sure that's where these problems are coming from.
Has anyone else run as much weight as this on the single rims/lugs?
I'd run a cutting disc down through the nut and stud from one side to the other just short of hitting the rim and then try to split the nut of. It's worked for me before.
Dan.
We see stretched lug studs/bolts a lot on smaller vehicles from over-torqueing. It would be a good idea to replace all the studs on the vehicle.
I hear ya bud... the solution is quite simple however.I'm just a bit nervous about damaging my $500 unobtanium rim.
Why don't you just unadjust the brakes, take the bearings out and remove the drum and wheel as one,
cut the inside lock nut off the stud, it would be alot easier!!!
