New Budget Build: 1994 Toyota Four Runner
slosurfer said:
subscribing.... I have a '93 4runner and done two different 6,000+ mile trips. They are great except for the power especially with the auto on the mountain passes. You are ahead of me on all the gear though, I will be paying close attention to your build. I too want to make my kit able to switch easily from the runner to our new '07 Taco Dcab. Having the M416 will help with that also. I also have a Thule Moab that helps, being that my son 2 yrs. old and our dog take up some room.
Here's the runner on a test trail run w/ the trailer
If Andy needs an M416 bad enough, he knows who to call.........
The Raingler cargo net/barrier arrived yesterday evening...I'll post the install and pics, as well as a little review here shortly....:ylsmoke: :lurk:
-H-
that is a good looking rig and for a great price! -We'll have to head out to the snow if it ever flys up in Flag this year :)
H,
Nice rig, I have some springs if you are interested (unless pskhaat wants them back) that I can send up to you for the cost of shipping. These are rear LC springs, which I have read can be used on the rear of the second generation rigs.
Jeff
DD...what! It snows in Flagstaff?
Jeff,
I'll likely not do LC coils on the rear, as I've heard they give about 5" or so of lift, which is a bit much.
In the past week I've made two mistakes....
1. Driving Senor Brady's EW Tacoma...
2. Driving Skeddy's (IH8MUD) 2000 UZJ100...
Both of which make the 4Runner a bit anemic.... :bowdown:
Now I've gotta figure out what platform to buy or build for the next "major" rig!
:box:
-H-
sounds like we need to hear a bit more about the demo:rolleyes:
No problem on the springs, wasn't sure what it did on the second gens, the 80 series gives about 3-1/2 on the third.
It is a neverending process, you think you're happy, then you see these other cool rigs.
x's 2
If you do want any info on the cruiser coil/bj spacer lift, that is what I have and I am really happy with it. It was actually my wife's dd with our son and she liked it. I got about 4.5" with the coils, that is over what my sag was. YOu can check out my sig for before and after pics.
Looking forward to pics of the net, right now I have a pet barrier, but that net looks like it will do the trick better.
If I remember right, the long side LC coils are the ones that give the 5" lift. The short side coils only give about 3.5" to 4" depending on how many miles are on the coils.
Now keep in mind those numbers are measured from a stock SAGGY BUTT height to the new height with the LC coils.
If you do go that route, make sure you get a pair of either long side or short side coils as one if each makes your rig lopsided.
Thats just what I remember from back when I was going to put the LC coils on my dads '91 4Runner with the BJ spacers. I actually had gotten a set of short side coils, but then I got my '98 and we decided to make that the offroader/hunting rig.
Depending on the one's you get it isn't really noticeable. I got a set from a '97 cruiser. I got 4.75" from the longside and 4.5" from the shortside. You can't really tell the 1/4" difference even if you know it's there. A matched pair may be the safest way to go though. I think slee's offroad will match up a pair of takeoffs.
I just remember a bunch of people at Yotatech were getting .5" and 3/4" or more differences in lift if they got 1 long and 1 short side coil. Apparently some years were worse for this that others?
Ok...well, about the "demo"....
I've been in some rigs with modified suspensions...but not that nice! The EW Tacoma is buttery smooth at speeds I would never have thought about taking my Land Cruiser at on the sandy road we were flying down!
....I guess Scott noticed my tightening the seatbelt and holding on to the grab handle...
Mucho fun! I'd never had the opportunity to do that type of driving before!
....now anytime Scott needs a navigator...:ylsmoke: :peepwall:
-H-
Raingler Cargo Barrier
Well, it finally arrived, the Raingler cargo barrier. $124.95, www.raingler.com
First impressions...
It was listed on the shipping invoice as a "universal" barrier" and not a 4Runner barrier, which concerned me.
Quality appeared to be good, with the stitching in place, and solid stainless steel hardware. Six mounting straps and cams were attached, three on each side at the top, middle, and bottom of the net.
No installation instructions, or suggestions for mounting points were included.
The Install...
After crawling into the back of the 4Runner, I found that the upper rear seatbelt bolts were likely the best place to attach the upper mounting straps. The seatbelt attachments had a place where I could run the strap through to keep it from falling down, and I was able to wrap the extra length of strap around the mounting.
The middle side mounting straps were run through the rear seat latch, and the bottom side mounting straps were run through the lower seat belt mounting brackets.
Once both sides were attached, I tightened the net, centering it as I went, and put the rear seats in their upright position.
Overall, I'm pleased with the net. There is a bit of room (6" or so) at the top, mostly due to having to mount the top straps to the seatbelt hardware, but I can live with that.
The net is tight and clean, and should withstand the type of abuse it'll see in this truck. It will definitely keep my SAR pack, stroller, and other gear out of the passenger compartment, which is all I needed.
As it is only attached to the seat belt mounts, it is definitely NOT a Milford Barrier. For a dedicated expedition rig, where I'd be carrying a fridge, recovery gear and other heavy items.....I'd spend the extra $$ and do it the right way, but for the low price, it provides inexpensive peace of mind that my little daughter won't get a stroller in the face should we stop suddenly!
-H-
Bobbyjr
