continuecrushing
Just saw a new DC to DC charger from Renogy on Amazon for $129, seems to have quite a few features for a relatively low cost. 40 amp model is $199
For sure beats (in my book) running a solenoid etc which ends up not being much cheaper. Downside of course is charging isn't quite as fast, but should be adequate for most of us I think. This makes it pretty darn easy to add in another battery and even do a quick connect type system where you only install the second battery when you need it as opposed to being installed 24/7. I know a lot of us don't care about having a second battery for self jump etc and mainly for running a fridge/electronics for the weekend.
Hell, I have a dual battery/charger setup and I almost want this for a 3rd battery/box that can easily go in/out of the truck yet still be charged from my existing wiring. Hmm lol.
From Renogy:
Description
This 20A/40A DC to DC Charger is designed to charge secondary batteries while driving using the primary battery connected to the alternator. It is able to charge: Flooded, Gel, AGM, and Lithium batteries using multi-stage charging.
Key Features
From Renogy:
Description
Key Features
- Multi-Chemistry Battery Types ( Flooded, Gel, AGM, and Lithium )
- Smart Protection Features ( Battery Isolation, Over-voltage safety, Overheat protection, and Reverse polarity protection)
- S3-phase Charging (Bulk, Boost, and Float)
- Built tough for all conditions
- Able to charge an auxiliary battery to 100% state of charge
- Increases run time of loads, such as fridges and lights
- Overcomes voltage drop caused by long cable runs
- Prolongs Battery Life
![renogy-dc-to-dc-charger-on-board-continue-crushing-overland.jpg](https://continuecrushingdotcom.files.wordpress.com/2019/04/renogy-dc-to-dc-charger-on-board-continue-crushing-overland.jpg)
![renogy-dc-to-dc-charger-on-board-continue-crushing-overland-charging-diagram.jpg](https://continuecrushingdotcom.files.wordpress.com/2019/04/renogy-dc-to-dc-charger-on-board-continue-crushing-overland-charging-diagram.jpg)
Renogy 20A DC to DC Battery Charger | Renogy 40A DC to DC Battery Charger |
Nominal Voltage: 12V | Nominal Voltage: 12V |
Rated Charge Current: 20A | Rated Charge Current: 40A |
Output: 250W | Output: 500W |
Idle Power Consumption: <0.4A | Idle Power Consumption: <0.4A |
Input Voltage Range: 8V-16V | Input Voltage Range: 8V-16V |
Equalization Voltage: N/A | Equalization Voltage: N/A |
Float Voltage: 13.2-13.8v | Float Voltage: 13.2-13.8v |
Boost Voltage: 14.1-14.7v | Boost Voltage: 14.1-14.7v |
Operating Temperature: -20°C to +50°C | Operating Temperature: -20°C to +50°C |
Dimensions: 8.31 x 6.89 x 2.68 inches | Dimensions: 10.28 x 6.88 x 2.68 inches |
Weight: 2.93lbs | Weight: 4.14lbs |
