New Member Hello!!
Scottn
Hello all!! I am just starting at this and will have a lot of questions that need answering. I am planning, and executing slowly but surely to fix up, my 01 Toyota Tacoma for a retire and go lifestyle, more like sell everything and live lifestyle. I have the basics, Truck with 3 inch lift, 32" BFG All terrains X5, solid engine.
I am looking at a AT FlipPack, Solar, Refrigerator, Suspension upgrades, etc. and need all you knowledge and advise.
Thanks for having me,
Scottn
WASURF63
Scottn
Welcome to ExPo! Sounds like a great plan.:smiley_drive:
Applejack
Welcome to ExPo! Slow and methodical is a good plan, and it sounds like you've got the basics down. From here it's just feeling out what you need.
I've had a couple of past projects that I spent way too much money on for things I didn't really need but just liked to have. If you have to be budget minded and it sounds like you will be, tackle most of your kit issues as they arise rather than trying to plan for everything, you'll never be able to do it and it's very expensive.:sombrero:
Scottn
I have a dilema now. I need some storage for my spare tire. I can either go with a TireGate hitch mounted carrier for $876 or go with a CBI full rear bumper with swing away and gas can carrier for $1350 unpainted, powdercoat for $200 or so.
I know the bumper will be nicer, just $700 is a big upgrade.
Opinions?
TangoBlue
American Adventurist
I detect some similarities... I retire next summer, was in the same position as you a couple years ago, we share the same year Tacoma, and may have similar modifications. A few more details about your truck would be helpful too, like model, engine, transmission, type of lift, and your current off road tastes.
I hate to break it to you, but you'll be spending a few more dollars mon frer. I got the disease bad, too... getting the IFS swapped for a solid axle starting next Monday.
Go for the bumper. You'll have intact bed capacity and can sport larger tires eventually yielding more off-road handling capability, and minimizing anything that can hang-up off-road from the rear of the truck (departure angle). I haven't heard many positive things about the TireGate from my scanning of the web, nor do I own one for that very reason; plus it robs you of secure carrying capacity.
Now the first corollary of off-roading: each modification results in the need for another modification. If you're going to sport a new rear bumper with carriers I strongly encourage you to add frame reinforcement plates to the rear frame. Just before the arch on the rear of our frames is a notorious weak spot where excess weight and rigors of rough terrain can cause the frame to buckle. The simple addition of those plates will greatly reduce the likelihood of that happening and give you a markedly enhanced ride. The added rigidity, I claim, gives our trucks a "Lexus-like" ride. Your butt-senso-meter may vary.
Now with all that space you can carry more gear! But maybe your springs and shocks might not be up to the task... ask me how I know. Or better yet, for a better description with pictures even, go to this site and spend a couple hours: http://www.expeditionswest.com/vehicles/ewvehicles/tacoma/index.html There are a lot of options though, and they can range from pretty simple, inexpensive fixes or major upgrades.
Stock curb weight for my truck is around 3,500 lbs. My truck as described below weighs 4,400 lbs. Add my basic load of recovery gear, tools, spares, pioneer kit, fridge and I'm at 4,700 lbs. Add camping gear and depending on duration and location and I'm well over 5,000 lbs. Gasoline weighs in around 6.25 pounds and water at 8.3 pounds per gallon; my point is that weight is the enemy to our trucks.
Please keep us advised and welcome to the community. Portal members are always standing by to help you spend your money!
TEJASYOTA
WELCOME TO ExPo!!!
Remember that with our model year Tacos - the frame reinforcement is necessary to prevent bending of the frame.
Only if you plan for either a Tire Gate, a Flip-pac or a Custom Rear bumper.
Also, has your truck been inspected for the dreaded corrosion issue on the frames. There is a recall/warranty from Toyota.
That can be found here...
http://www.tacomaterritory.com/forum/showthread.php?p=1175875#post1175875
As for the spare tire - CBI also has a Tire Carrier that mounts on the receiver hitch. This way you COULD mount on either on the rear or front (but you would have to get a custom bumper or modify the front factory bumper to have a receiver.
Post up a photo of your truck now. :)
Check out my TTORA Garage section to see my build (with CBI components).
TTORA also has a small expo type thread section, that way you can check out other builds of the similar Tacoma model.
Glad to have you here!
gwhipp
Welcome to ExPo. It sounds like you have some nice mods planned. Keep us posted along the way. Have you considered a custom rear bumper?
I had Hefty Fabworks make me a bumper for my Frontier. They are located in the Springs.
Tdavis8695
