OBD II reader. Best bang for the buck?
I have a Scan Gage 2 that I move between my FZJ80 and Subaru-powered Syncro. Super-easy to move. To get some of the gage features to work (like MPH and MPG) you have to take a few minutes to make some adjustments. Otherwise, all code reading features work seamlessly.
Absolutely, if it is a modern vehicle. These days you can talk to every device in the vehicle through the OBD2 interface - you just need the right hardware and software. What make / model / year are you specifically wondering about?
2005 Ford Excursion (Check engine light is on and I hate relying on the Parts store guy to read and clear codes)
2006 Ford Freestar (currently having issues with the transmission, I think? ...no service lights on the dash however...)
2002 Ford Focus
Does anyone know if the Bluetooth OBD readers have software to work on my laptop?
I have a laptop with bluetooth, but not a smartphone.
Thanks,
-Dan
I was wondering how well that app worked, ordering one right now!
'cause I have been borrowing my buddy's scan tool.
You can also set up profiles for your different vehicles. Its a neat little tool to use while you are going down the road, you can see each sensor and what it is reading.
I think I have decided on a hyper tech it will allow to read and clear codes and adjust the speedometer for tires up to 54".
I have an ultragauge in my car, it is great for real time monitoring of engine temps, MPG, speed (you can adjust for oversized tires), etcetera. And of course you can read codes, even pending ones before they throw a check engine light. Even better, you can drive around and know exactly what is happening when the codes set, and you can have an alarm for pending codes. Plugs right into OBD-2.
For the Torque Pro, how do you figure what percentage of volume efficiency to input? It says 85% is what most are, but my mpg readings seem to be way off [too high].
Did a bit of reading up on it, it says to adjust the volume efficiency before you alter the MPG trim adjustment.
There is a volume efficiency gauge, do I set it at max what my truck can produce or the average what I drive? Max seems about 60% shifting at 5000 rpm....while I normally shift at 2500 which pulls in the mid twenties percentile.
This is one reason I like Dash command. It uses fuel lbs/hr vs odometer reading to get a damn accurate MPG reading.
Another vote for Scan Gage 2
Leave it in the vehicle all the time. Love the trip features. Do have to look up what the codes mean but reads them just fine. You can program it to monitor just about any feature on the engine.
MOLLYmaz
