FJR Colorado
Sirs,
I just had some Toyota oem steel wheels, acquired by my local tire shop, mounted to the truck. My only concern is the the front wheels. They have only taken approximately half the thread of the lug nuts. The guy at the tire shop said the reason is the the front hub bolts don't stick out as much due to the design of the front hub. The rear wheels fit perfectly. The wheels are 16X7 16 hole black steelies. He assured me it was safe (6 to 7 full turns on the nut) but it just doesn't seem right to me. I planned on replacing the hub bolts with longer ones to get them fully threaded, but if the wheels are in fact Toyota wheels, this shouldn't be necessary should it? Any advice would be greatly appreciated.
Thanks,
John
I wonder if this is a case of the wheels would fit if you popped off the center caps?
I know this was the case when I put FJ Cruiser wheels on a T-100 or FJ80.
In any case, based on the photo supplied, you have a potentially dangerous situation.
