On going project trailer
UK4X4
For those of you considering your own trailer builds...
here's a few pics of mine in its earlier state, then present, and I'll be now doing some more mods in the next few weeks.
originally purchased for my TJ......and generally expanded to every 6 months.
This was my first welding project...ever......
The general design and sizes came from various sources...I cheated and scaled of the photo's.
The main box is an ex military aluminum shipping crate with seals and pressure releases.....
since removed when I did the drop down tail gate
Roof tent is an old one from venezuela
Wheels and tyres are 32's off my old jeep
frame is 24" off the ground
The hitch bar was bought as it has manufacturing stickers.....so it was easy to register in TX....and is removable for storage and making the frame less than 8 ft.
originally it was fully welded, then I made the wheel arches and side pieces removable.
the box etc all just bolts on
My company will not ship a trailer overseas....however they will ship box's and bits....so everything comes apart for my next transfer
original design with open front frame, I got fed up with everything getting covered in dust and crap, Moab dust gets everywhere.....
Cut the end of the box and made it swing down, built a small "kitchen"
I made a nose cone to match the military container, using 1" steel square and aluminum panels for the weight.
making a two way slanted box took quite some time to get it right...
panels are glued and rivited to the inside, and is fully sealed and dis-mountable with 4 bolts, again for shipping.
underneath the main box and the front box is a 15mm rubber matt to seperate it from the expanded metal beneath.
http://i56.photobucket.com/albums/g165/POshaughnessy/Disco bumper/DSC_1502.jpg
The open side racks were part of a wilderness rack, the front and rear pieces, used each side.
presently has 12 volts and a 850A battery for ipod sounds and led lighting.
Upgrades for this month while grounded in the house ( wife is due in 4 weeks)
so i thought I do a project to keep me busy and out of the house....
Complete the 12 volt system to include switch panel, and permanently installed sounds and lights
Add in a 20 gallon water tank plumbed and with tap and possible a pump.
Build side cabinets to replace the open carriers, for higher kitchen position and dust proof.
replace the axle with one the correct width......as this 2500lbs chinese one is bent.......probably due to the hangers being narrow
Add permanent gas cylinder and plumb into upper kitchen.
Strengthen fender mounts as part of side box's.
I know I will have a lot of repeated panels etc with the removable box's which will take up useable space and add weight.
But I need them dismountable for shipping.....right now fully loaded I can lift a corner to stack rocks under the tyre..so a liitle more weight won't kill me.
The main box I can lift alone......just....
Hope this gives you prospective trailer owners a few idea's
Grim Reaper
Looks like a box with convenient transport wheels to me :)
Love the Nuge paint job!
Well thought out and I love the reuse of items. That's how I do things as well. It is fun to find new uses for old discards.
slosurfer
Very cool! I like how you made good use of other things. Also, I'm diggin' the designer duds on your dog.:arabia:
OS-Aussie
Ok, I have a couple of questions...
"The hitch bar was bought as it has manufacturing stickers" please tell me more on this part.
I see a Union Jack on top of the cooler and UK as part of your alias, where about in the old dart to you come from ? And last of all where in Texas are you living ?
:REOutCampFire03: :camping:
UK4X4
"The hitch bar was bought as it has manufacturing stickers" please tell me more on this part."
Being new in the country and not wanting to have hassles with registering a self build, I managed to get hold of a smashed up trailer front half....
Then with a copy of the sticker etc I registered my trailer under the original builder, dimensions are almost the same
"I see a Union Jack on top of the cooler and UK as part of your alias, where about in the old dart to you come from ? And last of all where in Texas are you living ?"
Yep originally from Bournemouth on the south coast,
was in TX for a year, then Colorado for a year and now I'm in bakersfield CA
I work in oil and gas and move around alot
OS-Aussie
Smart one on the hitch as insurance is also an issue with self build.
Cool, there are some good places to trip to in that area
Death Valley, Mojave Road and so many other great places.
The movements with work also explain the pack and ship the trailer part.
Are you a football or Rugby man ?
UK4X4
Football-rugby......
I never had enough friends for that........I was more a sailing-canoeing-windsurfing dude......
and during my last midlife crisis ....Kite surfing....now there's a rush.....
Injury's and hurt the same as rugby....just not the personal aspect..
15-20 ft jumps some times deliberate sometimes the wind and waves just takes over...
Any way back to the post..............................................................................................
I dug out the fab picks as I was intending to re-make the trailer for my growing family....
when I look at the chassis etc.......the changes and improvements I want too make I'd be throwing more away than re-using , and the wife is giving me crap about the mounting collection of spares and saved odd bits
So who would like to purchase 1/2 my trailer...?
ie the kitchen box, front box and roof tent in the pictures is not included,
but I will include another original condition main box.......
that is identical, just in original condition.
Zero manufacturing full high tensile aluminum container with 10 lid lock downs and pressure valve with full lid seal, top opening.
This is pelican case type sealing system with low weight and superior structure.
34wideX44longX24high"
EX USAF for aircraft cameras
The main frame with ball hitch wiring waterproof LED lights, chains, and extendable leg.
rear D tow rings and rear 2" hitch for bike rack etc
axles 2000" with 5x 4.5 Jeep TJ spacing, jeep aluminum wheels and almost new 30" BFG all terrains.
Wheel track is the same as a jeep/landrover....but the wheels stick out from the arches....
Clearance height to frame is 23" clearance to hitch is 23".
So a TJ or Disco with 4" lift is just right
Side open carriers, for both sides and twin adjustable height bars for a roof tent or whatever you want canoes etc etc.
main box and frame need paint but has zero rust as its only 1.5 years old since it was built.
Box/side racks/fenders and main racks are al removable, trailer bare
could take 2 dirt bikes for example, or a small ATV
front space between box and framecan hold a large cooler and two jerry can's.
So the bad the box has two broken catch's...Ok but you have another 8....
if you fitted a hinge one side and removed the good ones you'd be complete.
On my original one I just used a piano hinge
The frame is zebra and has a few stone chips....the box is USAF grey.......
Any one interested ?
I was thinking of $ 1200 as is, but the wife say's no way...so $ 850 and its your's....
Add paint load up and go exploring !!!!!!
I'll post in the for sale section too with pictures sans the bits I'm keeping...
UK4X4
Can somebody translate ?
I only speak English, Spanish, German and a tad french..
There are the
Plains zebras (subspecies: Grants (Bohms),
Damaraland, Chapmans,
Selous, Burchells (and the extinct Quagga).
Hartman Mountain Zebra and the Cape Mountain Zebra.
The Grevy's, or "Abyssinian" ,Damaraland zebra (Plains subspecies)
is the "Nugent" a lower new mexico species or a dirivitive of the inner Houston
3 toe'd variety ?
OverlandZJ
There are the
3 toe'd variety ?
:xxrotflma
Ted Nugent... 70's era rockstar who has (had?) a fetish for Ford Bronco's. One of his wildest creations is (was?) a Zebra stripped rig.
Very active in :REOutArchery02: hunting since his retirement. Recently had a rather strange TV reality type show.
Sorry for the diversion..
