Partner stove mod.. piezo ignition
More pictures please. I’d like to copy this idea. Thanks
1-jpg.475141
2-jpg.475142
4-jpg.475144
3-jpg.475145
Starting the mod tonight. I'll post up final pics once done. Just doing testing now and bending the igniter strap.
Thanks for posting this OP.
Cool mod, I can only imagine how much Partner would charge to add this an an option.
How well does the ignitor (push button part) hold up to the heat when you have something like a frying pan on the burner that's retaining heat in the stove housing?
Zero issues with mine. Probably couple hundred hrs of cook time, half that with heavy/large cast iron in the summer. The whole stove got hot enough that I placed it on cork pads so it didn't screw the table up.
Very cool mod, should had posted when I did my mod in 2009, never got around to it. The only thing I did not like was when you remove the burners to clean the stove the wires got in the way, May be a heat resistant quick disconnect from the starter.
I can tip the grill/burner back and still clean it. I don't need to take it out. And if I did, the connector off the end of the push-button is easy to remove.
The wires are quick connect at the piezo.
M meadow build
