Payload ratio
Reebavic
Freedom
What is the rule of thumb to respect for the pay load ratio for truck camper, for towing they recommend that you stay under the 85% #. That would be using the wet # Of the unit.
Most people carrying campers of any size (9, 10, 11') are over their payload and GVWR. Just don't overload your tires and axles.
My 8' Palamino pop-up in a 1996 Dodge 1500 weighed 7,000. GVWR WAS 6,400.
My 11' camper on a Chevy 3500 SRW was 11,150. GVWR wad 9,900. Same camper on a Chevy dually weighed in at 13,100. GVWR was 11,400. I had thousands of trouble free miles out of both rigs.
I guess there's no consensus on this. I'm thinking of putting a NL 8-11 on an '04 F350 SuperDuty. I'll be a few hundred pounds over weight but I need the 4-season capability of the NL. My alternate is a Lance 825 with significantly less 4-season capability.
There seem to be two schools of thought on this:
- Stay under GVWR!
- Don't get stupid. Put some airbags on it and go.
These two schools seem to be derived from primarily two sets of information:
- Don't exceed design specs
- I've done it and had no problem for thousands of miles
I've not really run into anyone who kept it reasonable (10% to 20% over) and decided it was a bad idea from their personal experience. I'm sure they are out there but this seems to be the vast majority.
Should I go with my engineering background and stick to design (knowing full well what 'design' really means) and get a Lance 825 that will stay within spec? Or, go with experience and get the better camper? I won't exceed axle limits or tire limits.
In my line of work experience trumps theory every time but you need to start with the theory to get to the experience.
The problem is that no really really knows. It’s a combo of every rig is different and the use cases are different (eg, top heavy?, towing?, FS roads or the Rubicon?, what mods?) and the fact that the GVWR numbers are a combination of OEM lawyers, marketers, state limits for personal vs commercial vehicle weights, and design engineers calculations of safety margins, crap tires designed to get best mpg but not carry weight, plus maybe other stuff we don’t know (steel quality? other mechanicals redesign that hasn’t been disclosed, etc).
I have no idea, but I really doubt that the OEMs actually test things to failure, do they? If so, Toyota would have the Truck of the year with the new Tundras instead of a dumpster fire of engine failures. That’s where the experience of others helps a little bit.
I think you just have to understand the structure of your vehicle, the effect of intended mods and how it will all work together with the weight you’ll run in different circumstances. It all ends up to be a big ¯\_(ツ)_/¯ . . .
Personally, I’d add a subset to your Don’t Exceed Design Specs/Stay under GVWR and make that Don’t Exceed Your Combined and Individual Axle WR (but know if your vehicle has a particular weakness). IF there’s any kind of consensus at all on this from the hundreds (maybe thousands?) of posts on payload, it might be that. If that’s what works for heavy commercial hauling, it may be the least squishy metric to be a hard stop threshold, but then again . . .YMMV!
They don't even truly test via a computer simulation, because scaling from prior knowledge is much more effective... what the payout for warranty and liability was on prior similar designs, etc.
Good engineering means being thorough... and satisfying the bean counters, marketeers, and lawyers, mostly.
I have gone thru the Regs for my jurisdiction (BC), both the Motor Vehicle and Commercial Vehicle Acts (a pick-up with a box on it is registered as Commercial here). Not much in there on GWVR. But the Gov does publish guides that state being over GVWR is illegal, so ...
Yes in Ca, no in the US.
My 2500hd gasser chev has a payload of 2800# or so. There’s a sticker in the glovebox that says maximum truck camper weight is 1995#. Seems pretty conservative considering it’s an eight foot box.
They are factoring in a couple of really porkie occupants. :)
They are throwing in a WAG and CYA to account for most campers being high-CG.
My '22 ram 3500 SRW short bed has 4200# payload on sticker but camper loading guide says 3300# max so it seems pretty common to under spec the camper weight vs payload.
Your Payload Rating is printed on a sticker on the inside of your driver's door jam. Whatever that number is for your specific truck, subtract 1,000 lbs. and that's the weight of the campers you want to look at. Once you buy a camper that weighs 1,000 lbs. less than your Payload Rating, you'll fill it with 1,000 lbs. of personal stuff, linens, tools, food, water, passengers, luggage, dog and/or kid stuff, etc.
I hate the standard 10k GVWR limitations…
Typical safety factors are included on all things engineered. I would safely guess 1.5 minimum…... im curious to hear what other think about this. I’m not a scientist, im just a working man.
But I can tell you it’s very important to understand stand your points of failure when overloaded.
1. Tires
2. Suspension
3. Axles
4. Frame
5. Brakes: Overheating or longer stopping distances.
6. Transmission: Slipping, overheating, or broken gears/driveshafts.
7. Engine/Cooling: Overheating
Understanding your individual weight rating for each component separately will help you make a well informed decision.
I’ve maxed out my payload in a 2500 and it rode perfect. I’ve also overloaded my truck with wet DG and I had to go 55mph on the freeway and was worried the whole time… roughly 2 tons of dirt in a ram 2500 megacab. My payload is about 2k…. Dumb but made it
Answer is: it depends on the vehicle. If say, an F250's gvw was "neutered" for tax / CDL purposes, then its neutered payload is irrelevant to its mechanical capability.
The most extreme example would be a Power Wagon. Its axles, drivetrain, brakes, frames, is functionally identical to a 3500 dually. The only limiting factor is the suspension. In that case I won't blink an eye going over GVWR once the springs are upgraded, up to whatever a SRW 3500 is rated at.
My 2dr JK Rubi is the other end of the spectrum. Rolling on 130lb 37s, it can't even safely stop at factory GVWR.
LukeSkywalker515
