Post up your drawer/storage system
I finally got some pictures of the storage I built for my Range Rover Classic. The plan is to put a drinking water tank in the cavity to the left of the drawers that is just covered up with panels at this point. I think I'm also going to get some different sliders for the fridge slide I made because the ones that are in there aren't as smooth as I would like them to be.
Cool drawer system. I'm also doing a half drawer/half fridge setup. Here's what I have so far and what I'm aiming for.
attachment.php
attachment.php
attachment.php
A bottle opener, I knew I was missing something!
I was going to make mine with an angle iron frame and then sheet it with plywood but I decided that was going to be to heavy and over kill so I just built the whole thing out of 3/4" exterior grade plywood with a few angle iron reinforcements where needed.
My buddy Mark over at cruisercrap.com can probably make some Rover ones for you.
The frame is going to be made mostly of 3/4" square tube. It's going to be light except for the fridge slide portion.
Here's what I have for now. It's OK, but there's too much wasted space and not enough organization too it. It works but I'd like something new.
I'm going to be building a new one soon. Double stacked shelves on the driver side, slightly raised platform on the passenger may make it into a shelf or lid. Also want to fill in the area between the shelves and the window on the driver side.
Thanks guys. The system is made of prefinished maple plywood, The Aluminum bar on top is to protect the wood from being scratched.
Here are a couple pictures of mine. I just finished it up and will be adding a sleeping extension to it this coming weekend. It is 5/8" laminate plywood coated with Herculiner. I still have some painting and Al trim to install around the drawer fronts, but here she is.
The slides are 24" from Lowe's. You can see the build photos by clicking here.
Here is mine; not anywhere as fancy as some, but it does help me keep organized. I keep my cooking gear on the bottom and table gear on the upper shelves.
some great set-ups here,,,,,
just noticed the bottle opener davegonz, nice almost hidden touch.
2eleven
