1stgenoverland
I noticed that there are quite a few people on here interested in doing diesel swaps into their stock pre 1985 toyota 4x4s. I know that I sure am. So I figured one thread to hear about different options available would be wise.
So first, Toyota Diesels, which are the most reliable, have the best power and torque specs, Easiest swap and easiest to modify. Which ones are best for overlanding and have the best hwy performance. Can a 3b diesel be made to fit?
Cummins Diesel, 4bt and 6bt....Why or why not. Can you make a 4bt quiet. Does a 6bt fit in the pre 85 toyota SFA, Do you need a lift kit to make the engine clear the axle...How much do they weigh?
Mercedes Diesels, 612 and 617...Does the 612 have enough power or is it pretty slow, Does it weigh more then its worth, How easy is it to modify to get more power. 617, To long, to heavy, does it clear the axle?
Vw Diesels, Light weight yes but are they good on the hwy pulling a much bigger vehicle they they were designed for. Reliability?
Other good diesels not mention just list them off with your opinions on reliability and performance and ease of engine swap.
Well thats all. Hope to clear some stuff up for people. After all...arent we all drooling over the possibility of a diesel swap :drool: :smiley_drive:
