quick revised/updated crank bolt question
Yeah, I don’t claim to be an expert. The engine they were working was a newer Mitsubishi V6, and I had assumed it would be the same or very similar process. I’ll try to find the video and link to it. It seemed to be a snippet of a professional training video.
It's an 2007 Outlander 3.0l V6 Mivec 24V (6V31). Here's the video: . My Montero SR has the older Gen-2 3.0l V6 (Mivec?) 24V (6G72).
Can’t believe my first post will be this: I had seen a video on YouTube on a timing belt replacement that suggested (and showed) to stamp a dimple in the top of the bolt every time it’s removed and reinstalled. They suggest it should only be removed and reinstalled 3 times—the dimples indicated the number of times.
Anyways, loving this forum! Been a huge help with my research. Just purchased my first used Montero—1998 SR 3.0 with 64K miles. I know what you’re thinking, but it’s a Puerto Rico/Guam spec Montero so it’s an oddball and doesn’t have all of the features and options as a US spec. I like to think it’s unique, and it certainly is here in the mainland when you compare it to the US spec ‘98 Montero. :)
I had one of those ('98 SR) when I was stationed in San Juan. Took me a while to figure out it was a 3.0L and was pretty bummed when I found out but loved it all the same.
One suggestion.... DO NOT PUT JB WELD IN YOUR THREADS.... don't be that guy. Ok, one more... use the factory specified washer as well, not a thinner one. I honestly can't believe I read that.
Catch it before the bolt breaks first and for most, but if you dont, they sell a time sert kit to drill and and tap to take a factory bolt into your crank.
Bobbyjr
