Replacing CV boot
ZooJunkie
Maybe because I'm new at replacing CV boot on this truck, but man what a pain. Anyways...I'll have pic of my last install posted so everyone can see how it's done the right way, without taking out the whole front axle, not that I did, but I sure came close to removing the whole front axle!
Step 1: Remove caliper and caliper hanger.
2. Remove front hub and the locking e-ring.
3. Remove retaining clip to inner boot, both sides, the small and large retaining clip.
4. Clean off the axle grease from CV joint.
5. There's a circlip keeping the inner CV shaft from popping out, remove this circlip so you can pull out the axle later.
6. Separate the upper control arm from the ball joint. Now is a good time to replace the ball join or flip it. This should give you enough room to pull out the shaft from the wheel bearing side and remove the CV shaft to replace boots. If not, you'll have to remove the lower ball joint. Don't forget to support your lower a-arm w/ your jacks!!
I think that's about it...this job shouldn't take you more than an hour per axle to do. It took me about 7 hours to figure out the best way to remove it... Now that I did one side, the other side will be easy. :gunt:
How do those work, Bill? I've replaced boots and found it not to be too tough, but it there was a way to do it without taking the tulip joint apart, that would be cool. It's not a split boot or something?
If you had Ind4x4's kit, you could remove the front hub and install both boots without removing the axle.
Rather than don't that lengthy step up above, all you would have to do is:
1. Remove all braking component. Hang the caliper so it doesn't put stress on your brake line.
2. Separate the lower ball joint from the receiver, or remove the 4 bolts holding it in place against the lower A-arm.
3. Separate the upper ball join from the upper control arm.
4. Separate the steering linkage, outer tie rod.
5. Pull out your front wheel hub.
Now if you don't have a way to expand your cv boot to fit over the outer cv joint, you won't be able to install them. With the kit like Independence4x4, you can easily install both inner and outer cv boot w/o removing the axle. I figure this process is more like 40mins per axle. Whereas it was taking me 2-3 hours to do an axle by removing it from the inner cv joint.
DaveInDenver said:
How do those work, Bill? I've replaced boots and found it not to be too tough, but it there was a way to do it without taking the outer joint apart, that would be cool. It's not a split boot or something?
The plastic cone that the kit comes with enlarges the cv boot to fit over the cv joint. So it's as simple as sliding it over the joint.
jgwarren319
