SAR JK r2.8 Cummins conversion
well, throwing parts at it, and getting there
of course, there's missing parts - good thing I paid a lot of money for amateurs to work on it.
not quite sure why they took the entire exhaust off
keep in mind that one of the big reasons to have someone else to the work was because it's me, myself and I who practice nothing but the safety third principles
ah well, it would be ironic to be taken out by a Jeep
and yet it's in
time to start refilling stuff. Underneath, it's about done - put the top together and it runs again... with that said, I've been cleaning up and will clean up more of the wiring
So here's why I'm so salty, when I picked up the not-finished-Jeep - the owner was going on and on about how terrible things looked outside of the engine compartment. At the time it confirmed my "just get it away because this is the happiest I'll ever be with them (low bar)" and yet they not only didn't come up with the video where they demonstrated the flywheel was bent (and I should have forced them to demonstrate what they 'found'). It was also my fault in being lazy and not wanting to try to remove the transmission on the floor (this is before the lift made it to my new rental shop). However, non-labelled parts, missing parts, taking things well beyond what they needed to be taken apart... I get small business, sometimes you take on stuff where you don't really know all the things you need to know - but listening to the owner go on and on about my stuff in some kind of salve for his soul just isn't something I'm going to abide with. With that said, this is a complete story. I've vented and done. I'm sure he does a lot of great things and some of the stuff in his shop show a great level of expertise and skill. So, despite that diatribe, I still wouldn't recommend avoiding them. For Land Cruiser stuff, he seems top notch.
shifter back in place.
never liked the heater hose connected to the motor because it kinked due to the tight bend.... but, BBC have a pre-molded hose....
now shortened.
just wiring left.... I'm doomed
very close
this side cleaned up
and closer here
so now just shorten the stock harness
this, rewelded, and rattle rattle will happen. I kicked the starter over tonight but the batteries are just too low to support that kind of insanity
I also need to connect the speedo loom (not to get it started) and I need to tie the stuff that runs behind the motor to the firewall
it runs... but it leaks
in other news, the turbo pipes are rewelded and in place
spent the rest of the evening playing cleanup but I think the issue is either a missing o-ring or not a fully seated fuel connector... simple, I hope
So let's put pre-paid on this.
wife drove it tonight and will drive it for a couple weeks so I can do some necessary and needed maintenance/additions to her Colorado
what's next for it - more soundproofing for sure. Absolutely change the dash to something that can monitor the functions of the Cummins. Make the cruise control work again. Probably regear it eventually to take advantage of the diesel torque.
Update:
I'm an idiot but I had a lot of help from Jeep (which refreshed my utter hatred of them).
So here it goes. Wouldn't start when very cold (less than 30F). Died going down hill. Gauge read 1/8 tank despite me 'filling it to the point it overflowed' a day or two before.
Finally get it into my shop and go to siphon the diesel out in prep for dropping the tank. Can get it to siphon. ******?!!!! thankfully I didn't have enough fuel to torch it....
many more words - most bad ones
The JKU fuel fill neck goes from the rear corner, down the fender, forward then over to the middle of the tank on the other side of the vehicle. Call it 1 1/2" diameter. I had to open up the fill neck to allow for a diesel nozzle to insert. The vent for the tank is just below that neck-down-spot. Basically the pressure from trying to fill it would keep the fuel spout from filling the tank. It would further cause problems because the narrow, winding route of the fuel filler pipe created a backup.... thus the fuel popping back out. I got maybe 2 gallons out of the tank - now it has 17 but it took me 45 minutes to get it into the vehicle. New filler line parts are incoming.
Now that it has fuel in it- the tank shows mostly full and it's a lot easier to start cold (go figure, huh?)....
and to all those people who blogged about putting a diesel in your JKU, you could have mentioned this...
and update - cold weather starting, below 40 degrees, you'll be cranking on it for a bit. Granted, it is slightly better but it certainly isn't like my Colorado diesels which pop off immediately.
Does it have glow plugs?
Have you confirmed they're wired up and working?
All the diesels I've driven with glow plugs have had no trouble well into the negative F temperatures.
-Dan
-Dan
Heat grid on the intake. It should have glow plugs, but Cummins decided not to for reasons (I hope).
5mouse
