SAR JK r2.8 Cummins conversion
I've seen these on my floor before...
something I didn't realize, it really looks like the Jeep JK bolt pattern for the 3.8 is the same as the Cummins r2.8... still deciding what I'm going to do... AX15, rebuild the stocker or just send it with the overkill TR4050
The bolt pattern on the Jeep 3.8 is *extremely* close to a lot of Mercedes stuff, because the NSG 370 6 speed is made by Mercedes.
When you buy a clutch, flywheel and throw out bearing for the 3.8 from a Jeep dealer they all have Mercedes part numbers and logos on them.
The bolt pattern on the r2.8 is SAE #4, and it wouldn't surprise me if that SAE standard was either made from Mercedes or visa-versa.
-Dan
first step, center the Jeep on the rack and start laying out how this is going back together
the wiring is an embarrassment - but I will fix it before it goes back together.... got a lot going on, but this is on deck for most of the rest of my focus
Back to this... but first, repairs
one of the wheels broke off (yay chinesium).... so welded new ones on
much better
and the motor is lurking
so quickwhatevertheirnameis charges big bucks for their adapter clutch.... but the clutch itself is just a cummins product
this is merely an adapter to use basically a GM pilot bearing
and because I'm so thrilled with them, so dimensions so you too can avoid them
GM pilot
so you need a sleeve this diameter
time to put it back together
I have no idea why the shop took the accessories off
they, of course, compounded the problem by only labeling a few of the bolt bags
hopefully these are the pressure plate bolts... again, labeling?
stopped there, my dial caliper is at the house not the shop... ah well, I had like an hour tonight to do anything
it amazes me at times how little I can get accomplished at any one shop time
installed the pressure plate
this weekend I have help to get the motor in the JK - but I need it ready to go.... and that is proving a challenge. Still need to find my measurement gauges....
as no one trusts anyone on the internet
with the trans attached.
fun aside, leave the t-case off, loosen the core support and the motor goes right in
like this
also fixed some power wires
and removed the driveshaft... for whatever reason the past people didn't but just held it up with motorcycle strap (and I implied they didn't give me anything)
so next is finish putting the motor back in, fix the wiring, find gauges, give to wife so I can change the timing belt on her Colorado (it's beyond due). I gave myself a week to get this on the road so we can take a bit of an out-of-town to Anaconda Montana then Yellowstone then Deer Lodge Montana to show my wife the cool car collection there... it should be a nice shake down.
push the motor back and hold it up with the engine cradle so I can get back on the lift
about where it needs to be
now the engine and trans are fully suspended (it's on the cross member)
I can push it back - we won't show how because it may cause some of the more delicate to lose sleep
jgwarren319
