Se7en62's '97 Cherokee XJ "GROOT" Overland Build
After another couple days of trial and error (not being an A/C guy) GROOT is blowing ice cold. In fact it's so cold that I had to turn the fan down this morning and adjust the vent so it wasn't freezing my hand on the steering wheel. - This weekend it will get it's windows all tinted to help maintain interior temps.
Tonight I'll install the new Pioneer speakers I picked up for next to nothing, then I'll start putting together the parts I need to convert the Chrysler 8.25 to discs. - The A/C ate so far into my time constraints and budget that the axle swaps will have to come after our trip to CO. Since that's the case, my new prioritized prep list is as follows:
  • Disc Brake Conversion for Chrysler 8.25 w/ New E-Brake Cable ($295)
  • Fabricate Rock Sliders ($60)
  • Finish Tucking Rear Quarter Panels
  • Front Wheel Bearings and U-Joints ($98)
  • Finish CB System ($73)
  • Recovery Points ($80)
  • Upgrade Engine Mounts ($104) <--Not needed, but I'd like these done in advance of the trip.
  • Window Tinting ($120)
  • Parachord Pet & Cargo Dividers (Wife is on it.)
  • Build a Cargo Compartment System for Pelican Cases and RTIC Cooler ($40)
  • Pelican Cased CO2 System ($165)
  • Pelican Cased Field-Repair Tool Kit ($24 for Tool Roles)
25 Days and Counting...
How's the coolant temps with the AC on and fully loaded?
I converted my '92 to 134a several years ago and it blew ice cold for the 2 years it was my daily. But after moving to a bad weather only vehicle for a couple years, I had to recharge it this year. Unfortunately, I can't run mine on the highway fully loaded or it runs too hot. I'll be addressing that issue in the future.
Mine was doing the same thing right before the compressor clutch seized. I think the overheating issue was being caused by the excess load the compressor was putting on the serpentine belt system, which actually slowed the fan speed and water pump considerably. The new compressor is working like a champ and it's ice cold inside, while the engine temp remains between 209° and 219°.
:wings:
what exactly are you getting for the conversion and where? id like to get might done before a 38 day trip in September
Wrench-A-Part - Find any ZJ, grab the emergency brake cable and everything from the backing plate out, minus the rotors and pads. Then order new rotors and pads from Amazon for $60. I guesstimated the cost, but that should be higher than what I actually pay.
On my XJ -> ZJ disc swap, the ZJ driver side ebrake cable was swapped. However, the ZJ passenger cable was not long enough. I purchased a liberty passenger cable per the advice of cherokeeforum. It had the correct length but not the correct crimp position at the lever end.
Let me know what part number you buy and if it works for you!
I've read that before too. So the Liberty's passenger side cable worked for you?
Libertys had 8.25s so if you run into them grab all the same parts and the disks will bolt on and you won't have to dremel the backing plates. Just make sure your pulling from and 8.25 because I can't remember the years
Sent from my SM-G930P using Tapatalk
So you're saying a disc brake KJ (Liberty) rear disc brakes and emergency brake cables are a direct bolt-on to the XJ?
I can't seem to find a decent write-up with pictures, since Photobucket took a steaming crap on the internet. I'll dig deeper tonight, but i'm pretty sure the yards near me have a couple of KJ's laying around. This is now priority number one...
I don't remember the letter designation but yeah, same axle same track just coil sprung. I never found a write up either just put it on yours the way you took it off and hook the axle cables to the xj tensioner if I recall. It's been a while since I've had one. My last rotted and seems like all the ones for sale here aren't much better
I attempted to rebuild the drums, since I had all the brand new parts laying around. - It didn't work out at all. Now I'm without a parking brake. I'm going to the Wrench-A-Part on Sunday to pick-up the KJ Liberty rear disc brakes, then swap them over.
While I was at it though, I tucked the rear quarter panels and they turned out pretty good. I trimmed the bumper inward a bit, but soon enough it'll get a new one that will look cleaner.
Two quick updates:
Saturday my buddy and I ran up to Belton to the Wrench-A-Part and snagged the parts needed to convert the rear drums to discs. The donor Jeep was a 2004 Liberty, so everything will bolt-up. I ordered new pads and rotors, as well as new soft lines (which i accidentally left at the yard.)
Then Sunday, my folks came up for a visit and my Dad lent a hand in building a shelf-system for the cargo area. We got it about 95% finished and it's looking solid. - We used 3/4" Ash Ply and a 2x6 to build the shelf. It's held together with (16) 1" L-brackets, (60) 1-1/4" coarse-thread drywall screws, with wood glue on each joint. Then we are using (4) 6" Turnbuckles to secure it to the newly carpeted cargo area.
Right now it's sitting in the garage waiting for the Silicon to setup, then I'll stain the rest of the exposed wood tomorrow with black wood stain.
The original plan called for the spare to be mounted inside, but it didn't measure up and make sense, so we scrapped the spare and stuck with organization. - Instead, the spare will ride behind the driver's seat for this trip. Then, when we get home, I'll either order a tire carrier, or fabricate one.
ELShockley
