Seahorse 920 case review.
tremors834
I received my Seahorse 920 case today, thought I would throw up a quick first impression review.
Overall considering it costs about $70 from Adorama, I'm happy with it. While it's no Pelican, it will suit my needs.
[/url][/IMG]
It's solid and sturdy. It seals well.
[/url][/IMG]
Gray button is the unlock to slide out the handle.
[/url][/IMG]
Hinges molded in using a pin as the pivot.
[/url][/IMG]
You can see the rubber O-ring just above the hinge. Replacement O-rings are available.
[/url][/IMG]
Semi-hard wheels. Seem sturdy, but no bearings are used.
[/url][/IMG]
Rotary Lock latch
[/url][/IMG]
The pressure reliefe valve is incorporated into the right hand latch. When the latch is opened, it relives the pressure. You see the small hole just below the bottom lip. I don't know how well it works, time will tell.
[/url][/IMG]
The handle is not spring loaded.
[/url][/IMG]
If your looking to protect some high valued equipment I would suggest getting a pelican or comparible case. If you looking to protect your wifes toiletries like I am, a Seahorse case will perform just fine.
I'll try to remember to return and update this when the case actually gets put to use.
empireoverlandza
