brianjwilson
Some sort of lost...
I'm hoping someone smarter than me (shouldn't be too hard to find!) can help me out.
I'm looking at a 2021 Ford E450 chassis, with factory second alternator (157 amp/hr). I want to use the second alternator to charge 4X 100 amp/hr battleborn lithium batteries, which will have their own battery monitor system, separate solar charger, inverter/charger etc. All of the "system" components would be from victron.
I reached out to an install company, and they recommended a Victron 230 Amp Cyrix based "battery combiner". https://amsolar.com/rv-battery-accessories/98-altcli230
Victron's component descriptions are really lacking. It appears to be designed as a battery combiner and not MPPT style charge controller/converter, so it would not top off the lithium bank. There is also a concern (I believe) that the lithium batteries would draw too much amperage at low idle and overheat the alternator potentially. Could there also be damage caused to the alternator with a sudden shut off from the cyrix based combiner?
Victron does offer 60 amp MPPT Orion converters/chargers that could be run in parallel.
My goal is to be able to comfortable run air conditioner off of the second alternator (through 3000w victron inverter) while driving (estimated 100 amp draw on battery system).
Any feedback would be greatly appreciated. This will be my first time with a lithium bank, I don't want to screw something up with a "standard" alternator trying to charge a large lithium bank.
