Martinjmpr
Wiffleball Batter
So, in doing further research on my current "issue" (see here for details), I thought I'd solicit input from 2nd gen Xterra owners.
Overall, my questions would be:
1. How well does the 2nd Gen Xterra do off road? I'm not talking about hard core, but trails about on the level of Shafer Trail in Moab, Saints John/Radical Hill/Red Cone in CO, etc (basically 4 on the 1-10 scale used in Trail Damage.)
2. What kind of real world MPG are you getting with the V6/auto combo? My research indicates the X has about a 21.5 gallon tank, what kind of range are you getting out of that?
3. What size tires are people running without modification? Right now I'm running 235/85/16 on stock wheels on my Taco and they are tight but they fit. I'd like to run a similar size tire since it seems to work well for me.
4. Is the X big enough to sleep in? The photos I've seen show a pretty flat load deck, so that's a plus. I'm 6'1" so I'd want at least that much space.
5. Any known weak points? Engine/transmission/T-case/axles? I've heard something about weak or fragile axles but if that's only when doing hard-core rock crawling, it's not something I need to worry about. How well does the electric T-case shifter work? I'm leery of those but OTOH my wife's GV has that and it seems to work just fine (of course, her GV is full time 4wd so it's not like we have to shift it at all during normal driving.)
6. How noisy is it? My Taco is a fairly noisy vehicle so as long as it's not noisier than that, I won't even notice.
7. Bottom line, if you knew then what you know now, would you get another X?
Thanks for any input. :elkgrin:
