Single drawer build & rear organization system
That’s a good idea and sounds more flexible.
The routing of wires wasn’t as bad as it looks. I went through the factory boot that I believe is used for the rear taillight, removed 4 of the trim panels and fished the wire through using a zip tie
Next on the list is the cage, which I’ve decided to build from 1/2” steel. Originally I wanted to do it out of 1” aluminum for weight savings but the 1/2” square steel tubing isn’t bad at all and a good compromise.
How is the Monster liner holding up? Just built a platform and am considering similar but am worried it will start falling off in chunks like other products I have used like this on wood.
Thanks! Looks great BTW
It’s been super durable no issues so far. Looks the same it did the day I put it on.
I think the key is the chassis saver undercoat. I put 2 coats on, lightly sanded the final coat for before applying the monstaliner. I believe I put 2 applications of monstaliner on as well
If I built another one, I’d do it again the same way
Good to hear. Thank you!
Got the fridge cage put together. Primed and ready for paint
One more. I left a little room between the top of the cage and the top of the lid for maybe a cutting board or something. As you can see I also only used the criss cross lattice look on one side to save weight. The drawer blocks most of the right side of the fridge so figured why waste the metal and add unnecessary weight. Also the left side with all the lattice work can be used to secure things too if need be
The cage will be secured to the base using the same T-nuts I used to bolt the slide down
Got a few things done today.
Just need to add an inline fuse at the second battery that carries power to the drawer and put the drawer back in place
Great work! Very impressive.
Curious, what is the point of having a fridge cage?
Seems like you can pull the fridge out to use with the back loaded up and nothing will backfill behind the fridge keeping you from pushing it back in. And has a couple good spots to attach smaller things to.
empireoverlandza
