Smaller propane tank source
Yeah I have been thinking about the little tank thing for a while. I hate having all these empty 1lb ers lying around. I am not sure what to do with them. Anyway, its not just that the tank is expensive, then you have to add all the hoses and fittings. For instance I have a small grill and a single burner that I always use. You could easily spend another $50 on that.
I have had great luck refilling the 1lb tanks with the adapter that Harbor freight sells. Just need to freeze the 1lb tanks overnight first. I also find that leaving a little in the 1lb tank helps get them almost full. The best part is you can refill and always have full tanks with you. I have two of the 1 1/2 gallon propane tanks for the trips with larger number of people. Cooking and lighting just burn up too much propane when the number of people gets over 10.
Camp Tonneau Tents
