SOLD: Flippac Camper 8ft
kjcummins
I’m building a camper so I will no longer need the flippac. It has a small electrical system(you need to wire in a battery) with led light strips, usb/cig plugins all wired through a a 12 slop Blue Sea fuse block. It also has a small 300 watt inverter. The pos/neg power leads are ran out of a waterproof solar gland on the passenger side to wire into your vehicle battery or aux battery.
It also has a t-slot rail on the driver side to mount things to.
It does leak a little around the hinges on the front and could use a little work on the paint but overall it’s in good shape. It does have a custom aluminum back door on gas struts with lockable latches.
Asking $2250. Located in Idyllwild, CA. I can help you load it, if needed.
5mouse
