REZARF: FWIW, in my search for a stainless sink for my trailer build I discovered Home Depot has small RV style stainless sinks on the shelf for about 40 bucks. Ask for bar sinks.
Personally, I think that stainless one you made is perfect! I love how it mounts and looks nice and solid!
Drew
Thank you! That's ALOT better price for the sink assuming the drain would not interfere with the propane tank placement and it could be mounted securely.
SOCALFJ I'd be interested for sure. How does it hold onto the water tank? Can you post pics of that?
I have a SS angle bar bolted to the side box; takes 15-seconds to install/remove the sink. I'll need to take more pics including the QR drain when I get home tonight.
Andrew Walcker That is one of the slickest upgrades I've seen for the Horizon, BRAVO! I've been messing around with a plastic tub in the same position but this is light years ahead of it. Are you planning on making another run becuase I'm interested if you are.
Thank you Andrew! That's what I tried to use but as you know it's a total PITA. Plus this sink design worked out really well in that it's deep enough to even wash a few dishes if you want/have to but still fits in the shelf space above the slide out stove on the sidebox. I'll post up pricing for with and without the drain...but this ain't a cheap accessory :-o
