Steering Wheel Swap?
desertspeed
Has anyone swapped out an older steering wheel with a newer one, either from a newer van or another Ford model? My 2000 wheel is getting tired and I would rather upgrade to a better quality leather, etc. My biggest concern is that the airbag still work. Any info would be great.
I may try to pick up a newer F series wheel and see if the spline and wiring are comparable.
mgmetalworks
The new F-series steering wheels are totally different. The van has a splined steering shaft, the trucks have a hex steering shaft. Plus the clocksprings are way different. I've researched this swap a bit and it would be a lot of work and require some custom parts...that is, assuming the clocksprings could be swapped with little to no hassle. That could be a can of worms all by itself.
The steering wheel in the vans is virtually unchanged for many many years. Should be easy to find a direct replacement.
naterry
13 Cheeseburgers
They sell ford hub conversions for every major steering wheel manufacturer. Sparco:
Clemtiger84
