Stock white 1985 4Runner SoCal 5speed
85runnerup
image.jpgimage.jpgimage.jpgimage.jpghttp://losangeles.craigslist.org/sfv/cto/4844160853.html
1985 Toyota 4runner 4x4 22re 5 speed manual
VERY FIRM on price of 3,500.
Runs well, doesn't overheat or leak from anywhere. Shifts well in each gear, no pop outs, doesn't 80mph on the freeway.
Most of the accessories work:
Hand crank windows, rear power window, brakes, high and low beams, turn signals, CD player, horn, etc.
No heat, no A/C. Needs carpet. $250 for a new carpet kit online. There are some minor dings, scrapes and little rust spots.
New timing chain, new timing chain cover, new hoses, water pump. New rear drum brake shoes and parking brake adjusted.
Valves adjusted, new spark plugs and wires, new distributor, new dump style exhaust, new fuel filter, fuel injector cleaning service, new MAF (Mass air flow) sensor. New drivers side window regulator.
Hubs lock smoothly, 4 HI AND 4 low work very well.
Has hidden kill switch and alarm system with key fob.
New michellins LTX2 all season 31x10.50 r15 tires on stock Toyota steel wheels with 1.5 wheel spacers in the front and have the rears spacers but haven't installed yet.
Clean title in hand.
Tags good until June 2015
85runnerup
I added a few. Carpet is trashed and I'm replacing that In a week. Drivers seat needs to be redone. Otherwise it's pretty fair.
Clemtiger84
