Storage cases
Fresno
The DU-HA Tote is a portable storage unit that's designed to hold your gear, tools, rifles, shotguns, ammo, and anything else you may want to store securely in the back of most SUV's and pickup trucks. It's constructed from heavy duty polyethylene and comes with a lifetime warranty. The Tote is also a legal gun case in most states and holds up to 4 rifles or shotguns with or without scopes in an upright position.
http://www.du-ha.com/images/70103_images/70103_du-ha_tote_wht_bkgd_IMG_3016_lg.jpg
Install the Tote securely in your vehicle using the Tote Slide Bracket.
• Prevents the Tote from sliding around unsecured in your vehicle
• Allows you to access the Tote while standing outside your vehicle
• Allows you to lock the Tote in your vehicle to help prevent theft
• Includes locking mechanism
• Made of heavy duty aluminum
• Removes easily when not in use, to return vehicle to flat floor
I really, really like the idea, and I see this being used to store and transport for those of us that don't have the luxury of a safe. That being said, I hope it has close to Pelican/Storm-like build quality. Wish it had latches on each end as well, also less than impressed by the look of the hinge. The size and shape remind me of a custom cutout case I had made once made for a laser receiver mast and, though the case walls were as thick as a regular Pelican case, the length made it very torsionally flexible and the lid was almost floppy when opened.
When I first saw that I could have swore it was a brightly painted Dragon missile.
Jlbeats
