Stratos Suspension seat
Stratos
Hi Kerry. Still trying to get the pics worked out huh?
I've fitted heaps of them. I'm sure they don't do a specific bracket for the FG yet so you have to fab your own. Not a hard to do. They still retain the slides. It's a bit wierd for us because our DOT won't let us fit a suspension seat if the seatbelts are attached to the cab instead of the seat. So when we fit them, legally we have to but a bolt in the mechanism so that it can't move. Definitely check this with your DOT first.
BTW Kerry if you are a tall guy with long legs its not so simple. Im fine at 5"10 in those seats but if you're really tall we've even had to cut a recess in the cab for the back of stratos seats to slide into.
http://im1.shutterfly.com/media/47b...WrVmzZMge3nwI/cC/f=0/ps=50/r=0/rx=480/ry=320/
Thanks. There happens to be one for sale just a few miles from me so I will try to pick it up.
Just looked at the dimensions of the Stratos and measured the Fuso seat. Looks like a flat steel plate with holes drilled in the location of the original Fuso seat bolts allowing the plate to be bolted to the sliders and a second set of holes thru which the Stratos can be bolted should work. Is that how you did it?
Wolfbox
