kentoe
I just picked up a Dometic fridge over the weekend off Craigslist (CFX35-US) and I'm stoked. I was looking for some advice on re-wiring one of the 12v plugs.
I set the battery voltage detector to high since I'm just using the stock battery currently but noticed that when I shut off the Jeep it doesn't really stay on like it should on the non ACC cigarette lighter. I'd expect atleast a few hours if not a day from what I've read. However, I noticed after lots of googling that it makes sense that it's not able to accurately measure the voltage from those plugs and the thin OEM wires.
I wanted to cut the 12V plug in half and wire up some Anderson powerpole connectors to it and the other half so I could re-use the cigarette lighter function if need be. However, I wasn't sure what to use to wire the fridge directly.
If I was going to run a direct power to the fridge for the rear from the battery, would it be fine to use 14 gauge wire with a 7amp inline fuse? Or should I go with something like 10 gauge? I was contemplating putting a blue sea fuse box in the back if I ran 10 gauge, but I use the soft top and can't really find a good place to put something like that instead.
Any advice is appreciated! Worse comes to worse, I may have to pickup a power pack from amazon in the meantime and just in case since I'm only using one battery.
![i-7cRBvqQ-L.jpg](https://photos.smugmug.com/photos/i-7cRBvqQ/0/3187d23b/L/i-7cRBvqQ-L.jpg)
