Suggestions to Improve Hiace Clearance
DirtroadsNV
Hello all,
My bride and I picked up a sweet 1994 Hiace campervan in February and we are having a good time getting it out into the NV desert. It is a capable 4x4 machine, given it's heavy weight and small tire size, but the low clearance between the front wheels is killing us.
I have played around with my gains if I adjusted the torsion bars, and didn't gain that much and maxed out the suspension. Bigger tires seems to require significant modification of the fender wells, doors, and air filter space. I can armor the bottom, but that's not ideal.
Does anyone have experience, ideas or suggestions on how to get a couple more inches without a huge front end suspension fabrication/mod?
Thanks,
Manny
Lovetheworld
Which model do you have? From the tiny pic it doesn't look like a super custom.
They come with coil or with leaf springs. Always Torsion in the front.
Ours is with leaf suspension. We raised it roughly 8 Or 9 cm. Half of that in suspension, half with 225/75R16 wheels, which indeed required bodywork in the front. The rear doesn't require mods.
There should be a post about this on HiaceHobo website.
taunger
