Tacoma Drivers, Please take note
ntsqd
Heretic Car Camper
Let me start this by saying that I am particularly sensitive to glare. I usually have to wear sunglasses on foggy days.
My dd is a 2wd turbo Toyota p'up. So I'm sitting about average height, not up like a 4x4 & not low like a sports car. Tacoma's, particularly the 2nd gens, have really glare prone headlights. Maybe y'all knew this and maybe not. If you're getting flashed for low beams my guess is that this is why. When I'm driving my 4" lifted '91 Suburban I try to keep my headlights out of the mirrors of those I'm following. I figure that's the civil thing to do. Even unlifted Tacomas really nail my mirrors good and lifted ones are worse. I don't think there's a solution, but maybe awareness of this will help.
HTH
Accrete
Agreed. Our 07 TRD 4x4 TACO is my wife's DD and gets the flash by oncoming drivers often. Though i can also state that my Toyota Echo gets flashed quite a bit also. And once i was driving our Volvo X70 Cross Country and saw my wife coming toward me in our Echo and those lights are bright !!! No wonder i was getting flashed all the time. Crushing. I thought it was my good looks. grin.
Happy Trails,
Thom
edgear
aventurero, Overland Certified OC0012
The only time that oncoming drivers flash their highbeams at me is when I'm loaded down with a lot of heavy gear in the bed. I should either go in & figure out how to angle my headlights down, or get a 10 or 11-leaf spring pack & longer shackles, so that I don't ride so low in the back when carrying a heavy load. I like the 2nd option better!!
DaveInDenver
Middle Income Semi-Redneck
You're supposed to aim them with a typical load. That being a royal PITA, I just aim them with several bags of sand in the bed and that's close enough. Turns out to be a pretty good deal since when my bed is empty is when I'm driving around in town and having them aimed a little low attracts less attention of John Law and annoys less people.
toyota_jon
ahhh yes this is why i LOVE my e-code headlights. (no not those awful blue things) these lens are actually brighter that normal dot headlights but they're actually less obtrusive to other drivers with the way the lens is cut. i am very particular about my lighting, i HATE having dim headlights, like those on my girls truck. i don't know why the US doesn't use the same headlights as those in europe.
Photog
I know the 4Runners had a habit of spring sag in the rear. This will raise the low beams up into everyone's eyes. I don't know if the Tacomas have the same problem.
It isn't that much trouble to adjust the headlights. I've done it on my '88 and '04 4Runners. With a lifted truck, all the factory specs are not functional. Here is the process I use. (Note: you want the low-beam light to angle down from your head lights)
1) I pull up to a building in a flat parking lot (at night). Set the headlights for low-beam. I get out and mark on the wall, some distinguishable part of the beam, with electrical tape. The beam usually has a bright spot, or a sharp line at the top.
2) Get back in, and back up slowly. If the headlights are angled down, the part of the beam that you marked, will steadly move down from the tape you put on the wall. Both beams should move the same amount.
If the headlights are adjusted too high, or your springs have sagged, the beam will move up from your tape mark. Stop the truck, and turn the adjusting screw to bring the beam well below the tape mark (write it down each time you make an adjustment).
You could do this with the high-beams, and keep the beam on the tape mark, as you back up. Then check the low-beams to make sure they move down.
If you wrote down your adjustments, it will be easy to go back and make minor adjustments, to taste. (write these adjustments down too).
Rexsname
Can someone please post a picture of the adjusting screws! I would love to adjust the headlights but I have no idea where the heck this adjustment is done.
REX
Willman
This is true for all lifted rigs!
Note taken!.....Mine are perfect!...Don't have to worry about me.
Willman
This topic really should be in the General discussion area.........
This goes for everyone!
:REOutArchery02:
Photog
REX
I don't have a picture; but here is a description of the location and building an adapter to adjust the 4mm screw.
Quote from Chum, on 4X4 Review
.......... It is easy to do if you have a 4 mm socket or a 4 mm wrench. You don't have to remove anything. None of my metric sockets or wrenches are that small, so I made an adapter "tool." If you look at the backside of each headlight, near the bottom of it, you will see a long, slender screw. This is the vertical beam adjusting screw. If I remember correctly, if you turn it counter-clockwise, you pull the bottom of the headlight assembly "in" towards the passenger cab and the beam is lowered.......... The "tool" is a 10-32 x 5/8" long (1/2"or 3/4" should also be OK) Allen socket head capscrew. If it takes a 5/32" Allen wrench, you have the correct one, because 5/32" is essentially 4 mm. Place a couple of 10-32 nuts on the capscrew and tighten against each other. Make sure that the flats on the two nuts are aligned. The 10-32 nuts usually are 3/8" inch. Slip the socket end of this "tool" over the end of the headlight adjusting screw and use a 3/8" socket (1/4" drive works well) over both nuts and do your adjusting. Cost for the capscrew and nuts are less than $1. Good luck!
End Quote
edgear
Willman -- I moved this over into the General Vehicle Modification area.
Photog -- thank you for the detailed description & advice on how to properly adjust the low & high beams. I need to try this out!
computeruser
Not sure if this helps the Toyota crowd, but here it goes...
One of the joys of having a vehicle that takes non-proprietary lights (Jeep TJ, 7" round lamp) is the fact that non-DOT lights can be swapped in. I tow a lot with the TJ and often had people flashing me for my "highbeams" being on when a trailer was hooked up. The trees and street signs were well-illuminated, but the road was only so-so.
Enter the Euro-spec replacement lamps from Hella. They cast almost no light from 9-2, with a sharp horizontal cut-off that keeps the light on the road and not in the sky. The logic of this pattern is that unlike here in the US, the streetsigns in most European countries are illuminated and the vehicle lamps aren't required to illuminate signs. The results are quite impressive and very satisfying. When I come up behind other drivers, I can see a sharp light cutoff line across their trunk lid, and almost no light entering the vehicle itself. This setup is also much more friendly to vehicles ahead and oncoming traffic when the assend of the vehicle is loaded down.
If adjusting alone doesn't solve the problem, I guess it might be looking into whether Euro-spec non-DOT lights can be had for your vehicle.
bigreen505
I used e-code lights for about 10 years, but they are REALLY expensive for the Trooper (upwards of $1000/pr), so I am running the standard lights with slightly better bulbs (GE Night Hawk). Honestly, I don't understand how anyone thinks standard DOT lights are safe.
Also, e-code lights are very easy to aim, DOT lights are nebulous at best.
OverlandZJ
Very nice write up in that link bigreen505! I recently swapped in E-Codes and have it close, i'll adjust soon using Daniels writeup.
HenryJ
Aiming headlamps
Tools you will need -
* A dark area with a vertical wall you can drive right up to and about 25-35 feet of level room, measured perpendicular to the wall
* Chalk (for drawing on the wall)
* Cardboard or similar opaque material (to cover lights not being adjusted)
* Tools for adjusting lights
* A tape measure (or similar)
Prep the car –
* Fill the gas tank
* Equalize tire pressure
* Put a normal load in the car (your weight in the driver’s seat + weight for any regular passengers)
Initial positioning of the car –
* Put the car’s nose right up close and perpendicular to the wall
* Rock the car side to side to level the suspension
Mark the wall –
* Line "A" - Vertical, at the center (measured side-to-side) of the car
* Line "B" - Horizontal, at the same height as the vertical centers of the headlights
* Lines "C" - Vertical, at the horizontal centers of each lamp (2 lamps = 2 lines, 3 lamps = 3 lines, etc.)
* Line "D" - Horizontal, parallel to Line "B", 3 inches below "B"
Final positioning of the car –
* Keeping the car perpendicular to the wall, back it up until the lights are 25 feet away from the wall
Aiming the Low Beams –
* Turn on the low beams
* Cover one side (you'll be adjusting the other side)
* Turn the adjusting screws on the uncovered light so that the top edge of the light beam is at Line "D" and the angled cut-off point is centered on the intersection of Lines "C" and "D" (see illustration)
* Move the cover to the side you just adjusted and repeat for the (now) uncovered side
Aiming the High Beams –
* Turn on the High beams
* Cover all but one light (usually one of the center high beam lights on a 4-headlight system)
* On the uncovered light, put the center of the high intensity zone on the intersection of Lines "B" and "C" (using the appropriate Line "C")
* Move the cover and repeat high beam adjustment until all lights are adjusted
This will give you a good initial aim. You should "tweak" it if, after driving for a while, the low beams seem to be too high (or too low). Now comes the balancing act - trying to avoid shining your new (brighter) lights in someone's eyes, but giving yourself the best (highest) light pattern possible. Putting the light pattern horizontal cut off at or below the top of the trunk lid of the sedan on the road in front of you is a good measure. Keep it a little conservative, though, the last thing you want to do is attract the attention of the local law officers.
Notes –
This whole process can take about 30 minutes, make sure the gas tank is full and the engine is running so the battery is not drained. Keep in mind that you found that "dark", probably lonely, place to adjust your lights - it just might be a difficult place to find a jump.
No, you didn't use Line "A". It’s there because it's easy to locate and draw and it gives you some confidence in locating the other vertical lines. To locate the other vertical lines, you can draw line "A" and measure out the distance for each lamp (Lines "C"), after measuring those distances on your car, first. The step of drawing Line "A" can be skipped if you can get the car nose right up to the wall and the lines located that way.
If this is your first time adjusting lights, it might be best to sketch out what you want to do. Spend some time locating the correct screws/hardware, and see how the headlights move when the screws are turned one way then the other.
Adjusting the 2 high/low beam lamps (the outboard pair on a 4-headlight system) usually uses the same screws/hardware for both high and low beams. That is to say, you cannot adjust the high beam without messing up the low beam adjustment. Since the low beam is the more critical of the two, adjust the low beams and allow the high beams to go where they will (they’re usually pretty close). On a 4-headlight system, however, make certain the inboard high beams are adjusted properly.
Marka1
